Standard Symbols - Card Access
We are doing the design for a small casino HR building, for all the low voltage systems. We are an AV contractor, and don't have standards in place for other disciplines.
What are the standard symbols for something like a card access (for a door), and different types of data nodes? Searching for CAD standards is returning a lot of capacitors and scale blocks.
Thanks!
What kind of drawings, floor plans, one-line diagrams?
If this is just a one time thing, keep it simple. Rectangles and hexagons around a couple or three letters will suffice as long as they are included in your legend or utilize callouts and (TYP). If this may be for future use, you may want to be a little more representative of the device for floor plans and use some of the symbology found in more technical standards.
It's pretty much a one time thing. So I'm trying to keep it simple. I just didn't know if there were standards out there for this type of thing.
And it's for a floor plan.
By the time you find any sort of standard or guideline that you like, you could probably whip some up yourself.
A search for 'low voltage drawing symbols' resulted in this
http://preview.tinyurl.com/q7wjd7m
Ah, see, there we go. That's helpful. I've seen most of what I need before... but there are some random specialty symbols I don't know.
I thought that you would have already done that search.
  • 2 weeks later...
There's not much in the way of standards for low voltage, fire alarm, burg, or really any other low voltage system. Fire alarm does have a sort of a standard in NFPA 170 I think it is. When ever I do access control I just use simple basic stuff like CR with a box around the letters to show a card reader and MAG for a magnetic lock and DS for a door strike. The request to exit button and motion detector is RTE and of course CONTROL for the main power supply and controller unless your using a managed system then you need to show where the CPU will go. Audio/Visual contractor getting in the access control biz huh? What are you using for your DSP to control the paging system?
Cant get the link to work, want to see the pretty drawings!
I was googling the wrong words. I think I tried Access Control and Card Reader... stuff that was too specific.
@Ski_Me: I ended up using a simple ellipse with a number, so I could reference back to the Single Lines. We're not doing paging for this one... but we use primarily Biamp, BSS, and the occasional Media Matrix (when we're held at gunpoint).
Grew up on Media Matrix, even went to Peavey head quarters and met Hartley. Haven't used Biamp but I have installed a few BSS systems.
I wanted to ask you what system are you going to use for access control?
