Hi .I want to ask if someone have a lisp to calculate the area of layout print paper.
Thanks
hi tombu thanks for the reply. This lisp gives me the dimension of each layout,I want a lisp to culculate the area of the curent layout.
Thanks
Hi bigal . I need to calculate the printing cost for the current layout.
The first lisp code gives me the dimensions of all layouts . This lisp calculate the cost of the last layout . Can any one change it to calculate the cost of the current layout?
(defun c:test (/ lo wdt lg plotarea)
 (vl-load-com)
 (vlax-for lo (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object)))
   (vla-getpapersize lo 'wdt 'lg)
   (setq plotarea (list wdt lg))
      (princ "\n")
   (princ (vla-get-name lo))
   (princ "\n\t\tPlot size - ")
(princ
     (if
       (zerop (rem (vla-get-plotrotation lo) 2))
       plotarea
(setq area (/( * wdt lg) 1000000))
(setq pr (cond ((getreal  "\n The print cost €/sq.m (π.χ 2.30 €/sq.m monochrome  ή 3.50 €/sq.m color) : "))(2.30)))
(setq cost (* pr area))
(setq sx (cond ((getreal  "\n Give the number of copies (example 3) : "))(3)))
(setq scost (* sx cost))
 (textscr)
(princ (strcat
                  "\n Calculations"
                  "\n --------------------------------------------------------------------------"
                   "\n dimension x = "
                    (rtos wdt 2 2)
                    " m"
                    "\n dimension y = "
                    (rtos lg 2 2)
                    " m"
                    "\n Area of the print paper = "
                    (rtos area 2 2)
                    " sq.m"
                    "\n Cost per drawing = "
                    (rtos cost 2 2)
                    "\n Total Cost of Printing = "
                    (rtos scost 2 2)
Thanks
Edited by prodromosm
I update the code but i still have the same problem.This lisp calculate the cost of the last layout
Try this revised code...
 (vl-load-com)
 ;(vlax-for lo (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object)))
 (setq lo (vla-item (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object))) (getvar 'CTAB)))
      (princ "\n")
(princ
     (if
       plotarea
       (reverse plotarea); <<<<
(setq pr (cond ((getreal  "\n The print cost €/sq.m (p.? 2.30 €/sq.m monochrome  ? 3.50 €/sq.m color) : "))(2.30)))
 (textscr)
(princ (strcat
                  "\n Calculations"
                   "\n dimension x = "
                    (rtos wdt 2 2)
                    " m"
                    "\n dimension y = "
                    (rtos lg 2 2)
                    " m"
                    (rtos area 2 2)
                    " sq.m"
                    (rtos cost 2 2)
                    (rtos scost 2 2)
Henrique
@Henrique,
This:
Could become:
(setq lo (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object))))
:thumbsup:
Perhaps the code could be shortened to:
(defun c:test ( / lay len lst num prc wid )
   (if (= 1 (getvar 'tilemode))
       (princ "\nCommand only available in paperspace.")
           (initget 6)
           (setq prc (cond ((getreal "\nThe print cost €/sq.m <2.30 €/sq.m>: ")) (2.30)))
           (initget 6)
           (setq num (cond ((getint "\nNumber of copies <1>: ")) (1))
                 lay (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object)))
           (vla-getpapersize lay 'wid 'len)
           (if (zerop (rem (vla-get-plotrotation lay) 2))
               (setq lst (list wid len))
               (setq lst (list len wid))
           (textscr)
           (princ
               (strcat
                   "\n Calculations for layout \"" (vla-get-name lay) "\""
                   "\n ------------------------------------------------------------"
                   "\n   Dimensions: " (rtos len 2 2) " mm x " (rtos wid 2 2) " mm"
                   "\n   Paper area: " (rtos (* len wid 1e-6) 2 2) " sq.m"
                   "\n Cost per dwg: " (rtos (* prc len wid 1e-6) 2 2) " €"
                   "\n   Total cost: " (rtos (* prc len wid num 1e-6) 2 2) " €"
@Henrique,
This:
Could become:
:thumbsup:
Hi Lee,
of course it is much more logical to get the 'activelayout' object... :)
My intente was to show to OP that we don't need to loop through each item in the 'Layouts' collection, just get one, the current one...
Cheers
Henrique
I understand Henrique - my apologies for interefering with the lesson for the OP :)
Lee
Lee
Lee,
no need for apologies.
Your comments, explanations and codes, are always welcome.:)
Cheers
Henrique
