witchhero Posted June 6, 2015 Posted June 6, 2015 (edited) Sample.rar Hi friends, I found a VBA code from the internet. Code blocks according to the positioning coordinates in AutoCAD. code is working but for simple block. I wanted change for attribute block but I can not do. Who can help? I hope that me understand. because my english Too bad Option Explicit 'A custom type that holds the scale factors of the block. Private Type ScaleFactor X As Double Y As Double Z As Double End Type Sub InsertBlocks() '-------------------------------------------------------------------------------------------------------------------------- 'Inserts blocks in AutoCAD using data - insertion point, block name/full path, scale factors, rotation angle - from Excel. 'Note that the block name or the block path must already exists, otherwise nothing will be inserted. 'The code uses late binding, so no reference to external AutoCAD (type) library is required. 'It goes without saying that AutoCAD must be installed at your computer before running this code. 'Written by: Christos Samaras 'Date: 21/04/2014 'e-mail: xristos.samaras@gmail.com 'site: http://www.myengineeringworld.net '-------------------------------------------------------------------------------------------------------------------------- ' Define the block 'Declaring the necessary variables. Dim acadApp As Object Dim height As Double Dim acadDoc As Object Dim acadBlock As Object Dim attributeObj As Object Dim LastRow As Long Dim i As Long Dim InsertionPoint(0 To 2) As Double Dim BlockName As String Dim BlockScale As ScaleFactor Dim RotationAngle As Double Dim tag As String Dim value As String Dim prompt As String tag = "ATT1" value = Range("E3") height = 250 'Activate the coordinates sheet and find the last row. With Sheets("Coordinates") .Activate LastRow = .Cells(.Rows.Count, "A").End(xlUp).Row End With 'Check if there are coordinates for at least one circle. If LastRow < 2 Then MsgBox "There are no coordinates for the insertion point!", vbCritical, "Insertion Point Error" Exit Sub End If 'Check if AutoCAD application is open. If is not opened create a new instance and make it visible. On Error Resume Next Set acadApp = GetObject(, "AutoCAD.Application") If acadApp Is Nothing Then Set acadApp = CreateObject("AutoCAD.Application") acadApp.Visible = True End If 'Check (again) if there is an AutoCAD object. If acadApp Is Nothing Then MsgBox "Sorry, it was impossible to start AutoCAD!", vbCritical, "AutoCAD Error" Exit Sub End If On Error GoTo 0 'If there is no active drawing create a new one. On Error Resume Next Set acadDoc = acadApp.ActiveDocument If acadDoc Is Nothing Then Set acadDoc = acadApp.Documents.Add End If On Error GoTo 0 'Check if the active space is paper space and change it to model space. If acadDoc.ActiveSpace = 0 Then '0 = acPaperSpace in early binding acadDoc.ActiveSpace = 1 '1 = acModelSpace in early binding End If On Error Resume Next 'Loop through all the rows and add the corresponding blocks in AutoCAD. With Sheets("Coordinates") For i = 2 To LastRow 'Set the block name. BlockName = .Range("D" & i).value 'If the block name is not empty, insert the block. If BlockName <> vbNullString Then 'Set the insertion point. InsertionPoint(0) = .Range("A" & i).value InsertionPoint(1) = .Range("B" & i).value InsertionPoint(2) = .Range("C" & i).value 'Initialize the optional parameters. BlockScale.X = 1 BlockScale.Y = 1 BlockScale.Z = 1 RotationAngle = 0 'Add the block using the sheet data (insertion point, block name, scale factors and rotation angle). 'The 0.0174532925 is to convert degrees into radians. Set attributeObj = acadBlock.AddAttribute(height, _ prompt, InsertionPoint, tag, value) Set acadBlock = acadDoc.ModelSpace.Insertblock(InsertionPoint, BlockName, _ BlockScale.X, BlockScale.Y, BlockScale.Z, RotationAngle * 0.0174532925) End If Next i End With 'Zoom in to the drawing area. acadApp.ZoomExtents 'Release the objects. Set acadBlock = Nothing Set acadDoc = Nothing Set acadApp = Nothing End Sub Edited June 6, 2015 by witchhero Quote
BIGAL Posted June 9, 2015 Posted June 9, 2015 Here is an example of some code updating attribute values attribs = SS.Item(Cntr).GetAttributes If attribs(0).TextString = pitname Then pt1 = ThisDrawing.Utility.GetPoint(, " pick first point") txtx1 = CStr(FormatNumber(pt1(0), 3)) TXTY1 = CStr(FormatNumber(pt1(1), 3)) attribs(1).TextString = txtx1 attribs(2).TextString = TXTY1 attribs(1).Update attribs(2).Update Quote
witchhero Posted June 9, 2015 Author Posted June 9, 2015 Hi Bigal, Thank you very much for the time which you spent to me. The code is given by how I can integrate my own code? I'm not very good at coding,You can help me please? Quote
BIGAL Posted June 10, 2015 Posted June 10, 2015 I have stopped doing VBA it may be better to look at VLISP or plain lisp lots of examples to do the same thing. Quote
witchhero Posted June 10, 2015 Author Posted June 10, 2015 Thank you. My search continues, I hope my right Quote
piscopatos Posted June 30, 2015 Posted June 30, 2015 i was where you were. first you need to be able to make a list of your attribute values in excel sheet. in your sample in the sheets("coordinates") then you will use ; Dim varAttributes As Variant varAttributes = acadblock.GetAttributes For L = LBound(varAttributes) To UBound(varAttributes) varAttributes(L).TextString = devrekesici(k + 1, L + 1).Value Next the above " devrekesici" is a range that i assigned. it will be whatever you want it to be. hope this helps someone. Quote
witchhero Posted July 14, 2015 Author Posted July 14, 2015 Thank you very much piscopatos, its working !! Quote
piscopatos Posted July 18, 2015 Posted July 18, 2015 i am glad that it worked for you. Try to get into .NET API. it is abit hard but much more powerful. Quote
ZhiPing Posted August 6, 2020 Posted August 6, 2020 witchhero, can u up new remade code here:), thank! Quote
ducdudl2018 Posted September 7, 2020 Posted September 7, 2020 could you pls share your code?? Thankyou Quote
edmondsforum Posted April 26, 2022 Posted April 26, 2022 try this Option Explicit 'A custom type that holds the scale factors of the block. Private Type ScaleFactor X As Double Y As Double Z As Double End Type Sub InsertBlocks() '-------------------------------------------------------------------------------------------------------------------------- 'Inserts blocks in AutoCAD using data - insertion point, block name/full path, scale factors, rotation angle - from Excel. 'Note that the block name or the block path must already exists, otherwise nothing will be inserted. 'The code uses late binding, so no reference to external AutoCAD (type) library is required. 'It goes without saying that AutoCAD must be installed at your computer before running this code. 'Written by: Christos Samaras 'Date: 21/04/2014 'e-mail: xristos.samaras@gmail.com 'site: http://www.myengineeringworld.net '-------------------------------------------------------------------------------------------------------------------------- ' Define the block 'Declaring the necessary variables. Dim acadApp As Object Dim height As Double Dim acadDoc As Object Dim acadBlock As Object Dim attributeObj As Object Dim LastRow As Long Dim i As Long Dim InsertionPoint(0 To 2) As Double Dim BlockName As String Dim BlockScale As ScaleFactor Dim RotationAngle As Double Dim tag As String Dim value As String Dim prompt As String Dim varAttributes As Variant Dim varBlockProperties As Variant Dim Index As Variant Dim prop As Variant Dim propatr As Variant 'Activate the coordinates sheet and find the last row. With Sheets("Coordinates") .Activate LastRow = .Cells(.Rows.Count, "A").End(xlUp).Row End With 'Check if there are coordinates for at least one circle. If LastRow < 2 Then MsgBox "There are no coordinates for the insertion point!", vbCritical, "Insertion Point Error" Exit Sub End If 'Check if AutoCAD application is open. If is not opened create a new instance and make it visible. On Error Resume Next Set acadApp = GetObject(, "AutoCAD.Application") If acadApp Is Nothing Then Set acadApp = CreateObject("AutoCAD.Application") acadApp.Visible = True End If 'Check (again) if there is an AutoCAD object. If acadApp Is Nothing Then MsgBox "Sorry, it was impossible to start AutoCAD!", vbCritical, "AutoCAD Error" Exit Sub End If On Error GoTo 0 'If there is no active drawing create a new one. On Error Resume Next Set acadDoc = acadApp.ActiveDocument If acadDoc Is Nothing Then Set acadDoc = acadApp.Documents.Add End If On Error GoTo 0 'Check if the active space is paper space and change it to model space. If acadDoc.ActiveSpace = 0 Then '0 = acPaperSpace in early binding acadDoc.ActiveSpace = 1 '1 = acModelSpace in early binding End If On Error Resume Next 'Loop through all the rows and add the corresponding blocks in AutoCAD. With Sheets("Coordinates") For i = 2 To LastRow 'Set the block name. BlockName = .Range("D" & i).value 'If the block name is not empty, insert the block. If BlockName <> vbNullString Then 'Set the insertion point. InsertionPoint(0) = .Range("A" & i).value InsertionPoint(1) = .Range("B" & i).value InsertionPoint(2) = .Range("C" & i).value 'Initialize the optional parameters. BlockScale.X = 1 BlockScale.Y = 1 BlockScale.Z = 1 RotationAngle = 0 'Add the block using the sheet data (insertion point, block name, scale factors and rotation angle). 'The 0.0174532925 is to convert degrees into radians. Set attributeObj = acadBlock.AddAttribute(height, _ prompt, InsertionPoint, tag, value) Set acadBlock = acadDoc.ModelSpace.InsertBlock(InsertionPoint, BlockName, _ BlockScale.X, BlockScale.Y, BlockScale.Z, RotationAngle * 0.0174532925) varAttributes = acadBlock.GetAttributes varAttributes(0).TextString = .Range("E" & i).value varAttributes(1).TextString = .Range("F" & i).value varAttributes(2).TextString = .Range("G" & i).value varAttributes(3).TextString = .Range("H" & i).value varAttributes(4).TextString = .Range("I" & i).value End If Next i End With 'Zoom in to the drawing area. acadApp.ZoomExtents 'Release the objects. Set acadBlock = Nothing Set acadDoc = Nothing Set acadApp = Nothing End Sub Quote
