minhphuong_humg Posted June 11, 2015 Posted June 11, 2015 Hi, everybody. I have 2 xLine intersection. I want dimangular two xline. But don't work. I have to draw pline and dimangular Pline. Help me. Quote
Tharwat Posted June 11, 2015 Posted June 11, 2015 The dimangular command does not allow to select Xline , so after invoking the command hit enter to move to the second option by specifying the angle arguments. Quote
minhphuong_humg Posted June 11, 2015 Author Posted June 11, 2015 The dimangular command does not allow to select Xline , so after invoking the command hit enter to move to the second option by specifying the angle arguments. Can you describe in more detail? I used command DAN > Select arc, circle, line, or :............. Quote
Tharwat Posted June 11, 2015 Posted June 11, 2015 Can you describe in more detail? After invoking the command dimangular hit enter and continue ... Quote
minhphuong_humg Posted June 11, 2015 Author Posted June 11, 2015 After invoking the command dimangular hit enter and continue ... Select arc, circle, line, or : How countinue Tharwat? Quote
Tharwat Posted June 11, 2015 Posted June 11, 2015 Okay , hit enter after that and follow the command line ... Quote
minhphuong_humg Posted June 11, 2015 Author Posted June 11, 2015 Okay , hit enter after that and follow the command line ... Thank Tharwat very much! The problem was solved with the help of Tharwat! Quote
Tharwat Posted June 11, 2015 Posted June 11, 2015 Thank Tharwat very much! The problem was solved with the help of Tharwat! Nice, you are welcome . Quote
