I've just completed transfering my AutoCAD 2007 license file to a new workstation and have the program running on the new machine. How do I 'migrate' all my custom settings (toolbars, etc.) to this new computer as well?
Thanks!
James
I'm not aware of a way to keep your toolbar setup, but you can migrate your cui and pgp files to keep all your shortcuts and settings.
  • 1 year later...
Hi :)
I'am having a bit of trouble migrating my settings....... I clicked on the Migrate Custom Settings (AdMigrator.exe) and then it blurts " Migrate Profiles requires that Autocad 2000 or later version be installed on your system" even though I have Autocad 2007 installed....:?
Tried repair install and also registry repair of cad but still the same error message!
Is there another way how I can save my current settings?
you could try to copy your old profile to the new system as long as the support path are the same
Put the old hard drive in the new machine and move all the "custom" files you've created over. Then reformat the old HD and use it as a backup.
