i created a CUI macro to draw a revcloud
^C^Cpline;revcloud;arc;500;500;object;last;;
the macro draws the pline and dont apply the revcloud command
I am creating a CUI for the company I working in
What I want is, the user draws lines (pline) then those lines converted to revcloud .
I want to use the arc lengh as a standard for all user.
Any suggestions
When constructing a rev-cloud from a polyline, the polyline must be closed. I had two mins so this LISP will accomplish the same thing:
; Polyline Revcloud by Lee McDonnell 21/12/2008
(defun c:prev (/ *error* l1 l2)
   (defun *error* (msg)
   (setvar "cmdecho" 1)
   (if (= msg "")
       (princ "\nFunction Complete.")
       (princ "\nError or Esc Pressed!")
   ) ;_  end if
   ) ;_  end defun
   (setvar "cmdecho" 0)
   (prompt "\nConstruct Polyline.")
   (command "_pline")
   (while (> (getvar "cmdactive") 0) (command pause))
   (setq l1 (entlast))
   (command "_pedit" l1 "c" "")
   (setq l2 (entlast))
   (prompt "\nReverse Cloud Direction? [Yes/No]: ")
   (command "_revcloud" "o" l2 pause)
   (*error* "")
) ;_  end defun
is it mean, I can not do that using macro?
Well, lets just say that it would be awkward to use a macro to accomplish the same task, as the macro would have to make sure that the polyline was closed before performing the conversion to a rev cloud - I would personally opt for LISP.
Personally I like LISP but when dealing with more than 60 PCs and load the lisp on all of that.
In that case I prefer to make a CUI button (the menu is shared on server)
we can use that to be sure the pline is closed
^C^Cpline;pe;last;close;;revcloud;arc;500;500;object;last;;
Maybe for existing polyline:
; Polyline Rev-cloud by Lee McDonnell (Polyline Selection) - 21/12/2008
(defun c:prev2 (/ *error* ent ent1)
   (if (= msg "")
   ) ;_  end if
   ) ;_  end defun
   (while
   (setq ent (entsel "\nSelect Polyline: "))
      (command "_pedit" ent "c" "")
      (setq ent1 (entlast))
      (prompt "\nReverse Direction of Cloud? [Yes/No] <No> : ")
      (command "_revcloud" "O" ent1 pause)
   ) ;_  end while
   (*error* "")
) ;_  end defun
(got a bit carried away :P)
Mr. Lee
How do you write the LISP?
using a notepad, or what?
A while ago I did use Notepad, but now I use LISP Visual Editor (comes free with ACAD). Type "vlide" at command prompt.
