MastroLube Posted July 1, 2015 Posted July 1, 2015 Hi guys! I've something to ask about dictionaries in autocad. I'm using an addon that draw steel bars for slubs. Unfortunately it has some bugs and has created some void items so when i've to enumerate it gives wrong numbers. It stores data in dictionaries and i wanted to delete these items "by hand". How can i lookup and modify these informations? (defun C:LISTDICTS (/ ) (setq maindict (namedobjdict)) (while (setq adict (dictnext maindict (not adict))) (princ (cdr (assoc -1 adict))) (princ (strcat "\t(type = " (cdr (assoc 0 adict)) ")\n") ) ) (princ) ) Maybe inside that entity name i'll find my object.. maybe.. Can someone help me please? Thanks, Dennis Quote
rlx Posted July 1, 2015 Posted July 1, 2015 http://forums.autodesk.com/t5/forums/searchpage/tab/message?filter=labels&q=dictionaries maybe something there... gr.R. Quote
BIGAL Posted July 2, 2015 Posted July 2, 2015 Can you post a dwg you need to know name of dictionary and then name of items within that dictionary then you can add and subtract etc. Quote
MastroLube Posted July 2, 2015 Author Posted July 2, 2015 Hello guys! Sure! Dictionary exemple not sorted.dwg The not sorted file has the bars number in the order I've created them. Dictionary exemple sorted.dwg The sorted one has been sorted by diameter first and length then. Thanks, Dennis Quote
MastroLube Posted July 14, 2015 Author Posted July 14, 2015 I was trying using Superpurge, but i don't think it fits my needs. Can someone give me an advice? Quote
