mbrandt5 Posted July 2, 2015 Posted July 2, 2015 I'm curious of a way to have multiple blocks inserted and have the block insert a specified distance from the previous inserted block of the command... maybe using GetPoints just not sure how to do it... Here is a multiple insert lisp I found on forums here... (defun c:Insert (/ InsObj pt js ename nw_str) (initdia);brings up dialog box (command "._insert");starts command (while (> (getvar "cmdactive") 0) (command pause);;pauses for user input ) (setq InsObj (entlast)) (setq Inspt (cdr (assoc 2 (entget InsObj)))) (while (setq pt(getpoint"\nSpecify insertion point: <press ENTER to stop>")) (command "_.-insert" Inspt pt "" "" "")) (princ) ) Quote
fabriciorby Posted July 2, 2015 Posted July 2, 2015 (edited) try this very ugly code (defun c:Insert2 (/ InsObj pt js ename nw_str lastpt distpt) (initdia);brings up dialog box (command "._insert");starts command (while (> (getvar "cmdactive") 0) (command pause);;pauses for user input ) (setq InsObj (entlast)) (setq Inspt (cdr (assoc 2 (entget InsObj)))) (setq lastpt (cdr (assoc 10 (entget InsObj)))) (while (not(setq distpt (getdist "\nType the distance: ")))) (command "_.circle" lastpt distpt) (while (setq pt(getpoint"\nSpecify insertion point: <press ENTER to stop>")) (entdel (entlast)) (command "_.-insert" Inspt pt "" "" "") (setq InsObj (entlast)) (setq Inspt (cdr (assoc 2 (entget InsObj)))) (setq lastpt (cdr (assoc 10 (entget InsObj)))) (while (not(setq distpt (getdist "\nType the distance: ")))) (command "_.circle" lastpt distpt) ) (entdel (entlast)) (princ) ) Edited July 2, 2015 by fabriciorby Quote
Commandobill Posted July 2, 2015 Posted July 2, 2015 Are the subsequent blocks going to be spaced equally or a different space for each one? Quote
mbrandt5 Posted July 2, 2015 Author Posted July 2, 2015 Fabrício would you mind explaining to me what that code is doing exactly... Though it didn't work I'd like to learn more lisp in actual code versus just reading about it If not no big deal Quote
Commandobill Posted July 2, 2015 Posted July 2, 2015 Are you going to want to specify the direction, or will it always go in a specific direction? Quote
fabriciorby Posted July 2, 2015 Posted July 2, 2015 Fabrício would you mind explaining to me what that code is doing exactly... Though it didn't work I'd like to learn more lisp in actual code versus just reading about it If not no big deal It didn't work? Have you typed "INSERT2" to start it? If so, could you please print your console here? Yes, I can explain it to you, but print your console here first, let me take a look D: Quote
Commandobill Posted July 2, 2015 Posted July 2, 2015 It didn't work? Have you typed "INSERT2" to start it? If so, could you please print your console here?Yes, I can explain it to you, but print your console here first, let me take a look D: Not sure what you were trying to do with that code, but it def did not work. Quote
fabriciorby Posted July 2, 2015 Posted July 2, 2015 Not sure what you were trying to do with that code, but it def did not work. it works fine here, and fits the OP's objective but yeah, the code is ugly because my purpose was to modify the already existing code by the way, would you please print your console here too? edit: give it a try now, i've edited the code a little bit Quote
Commandobill Posted July 2, 2015 Posted July 2, 2015 it works fine here, and fits the OP's objectivebut yeah, the code is ugly because my purpose was to modify the already existing code by the way, would you please print your console here too? edit: give it a try now, i've edited the code a little bit Seems to be working now. There are definitely other ways of going about it, but you are right, it does fit his purpose. Quote
Commandobill Posted July 2, 2015 Posted July 2, 2015 Also, you don't need the first distance/circle call you have in there. Quote
mbrandt5 Posted July 2, 2015 Author Posted July 2, 2015 The direction doesn't have to be specified one direction would be fine... Customization file loaded successfully. Customization Group: ACAD Customization file loaded successfully. Customization Group: CUSTOM Customization file loaded successfully. Customization Group: AUTODESKSEEK Customization file loaded successfully. Customization Group: MODELDOC Customization file loaded successfully. Customization Group: CONTENTEXPLORER Customization file loaded successfully. Customization Group: APPMANAGER Customization file loaded successfully. Customization Group: FEATUREDAPPS Customization file loaded successfully. Customization Group: SKETCHUPIMPORTSKP Customization file loaded successfully. Customization Group: DBCONNECT Customization file loaded successfully. Customization Group: STEEL_SHAPES50 Customization file loaded successfully. Customization Group: EXPRESS Loading AEC Base... Loading AEC Base Extended... Loading AEC Core... Loading AEC Project Base... Loading AEC Architectural Base... Loading AEC Schedule... Regenerating model. Command: Command: Command: Command: Command: Command: Command: Command: Command: Command: Command: Command: Command: Command: Command: Command: Command: Command: Command: Command: Command: Al's STEEL MILL Loaded. Type STL to use.Steel Shapes 5.0 © by CCAD inc. 2010, AISC 13.0; error: no function definition: OBJSELECTION ; error: no function definition: AUTOLOAD Steel Shapes 5.0 © by CCAD inc. 2010, AISC 13.0 AutoCAD menu utilities loaded. Al's STEEL MILL Loaded. Type STL to use.Steel Shapes 5.0 © by CCAD inc. 2010, AISC 13.0; error: no function definition: OBJSELECTION Steel Shapes 5.1 by CCAD inc. © 2011. alt.LSP for AutoCAD is loaded. To view a slide of the fraction chart type alt. dfactor-feet.LSP for AutoCAD is loaded. To view a slide of the Drawing Factor chart type dfactor-feet. dfactor-inches.LSP for AutoCAD is loaded. To view a slide of the Drawing Factor chart type dfactor-feet. FILTER loaded. Type HDLINE to start._UNDEFINE Enter command name: EATTEDIT Unknown command name. VSF.LSP for AutoCAD is loaded. To view a slide of the fraction chart type VSF. AutoCAD menu utilities loaded.Steel Shapes 5.0 © by CCAD inc. 2010, AISC 13.0 Command: FileTab Command: properties Command: TOOLPALETTES Command: COMMANDLINE Command: Command: Command: Specify opposite corner or [Fence/WPolygon/CPolygon]: Command: Specify opposite corner or [Fence/WPolygon/CPolygon]: Command: Specify opposite corner or [Fence/WPolygon/CPolygon]: Command: *Cancel* Command: *Cancel* Command: APPLOAD DMZ.lsp successfully loaded. Grid insert .lsp successfully loaded. Command: Command: Command: Command: APPLOAD grid insert.lsp successfully loaded. grid insert.lsp successfully loaded. Command: Command: Command: Command: INSERT2 ._insert Specify insertion point or [basepoint/Scale/X/Y/Z/Rotate]: Command: Type the distance: 10' _.insert Enter block name or [?] <_archtick>: 15.40585711719873,15.02608410844836 Warning: If you are trying to insert the file: 15.40585711719873,15.02608410844836 it must be inserted using the = syntax. Command: 120.000000 Command: ; error: Function cancelled Command: *Cancel* Command: Specify opposite corner or [Fence/WPolygon/CPolygon]: Command: *Cancel* Command: Specify opposite corner or [Fence/WPolygon/CPolygon]: Command: *Cancel* Command: *Cancel* Command: Command: *Cancel* Command: *Cancel* Command: INSERT Specify insertion point or [basepoint/Scale/X/Y/Z/Rotate]: Command: *Cancel* Command: Specify opposite corner or [Fence/WPolygon/CPolygon]: Command: _.erase 2 found Command: INSERT2 ._insert Specify insertion point or [basepoint/Scale/X/Y/Z/Rotate]: Command: Type the distance: Specify second point: _.insert Enter block name or [?] <_archtick>: 14.16569767158643,14.80579059310322 Warning: If you are trying to insert the file: 14.16569767158643,14.80579059310322 it must be inserted using the = syntax. Command: 10.836104 Command: INSERT2 Unknown command "INSERT2". Press F1 for help. Command: Specify insertion point: _.-insert Enter block name or [?] <_archtick>: _ArchTick Units: Unitless Conversion: 0'-1.00000000" Specify insertion point or [basepoint/Scale/X/Y/Z/Rotate]: Enter X scale factor, specify opposite corner, or [Corner/XYZ] : Enter Y scale factor : Specify rotation angle : Command: Type the distance: Specify second point: _.-insert Enter block name or [?] <_archtick>: 24.16998484980846,13.68220803577576 Warning: If you are trying to insert the file: 24.16998484980846,13.68220803577576 it must be inserted using the = syntax. Command: Command: INSERT2 Unknown command "INSERT2". Press F1 for help. Command: INSERT2 Unknown command "INSERT2". Press F1 for help. Command: INSERT2 Unknown command "INSERT2". Press F1 for help. Command: Specify insertion point: _.-insert Enter block name or [?] <_archtick>: _ArchTick Units: Unitless Conversion: 0'-1.00000000" Specify insertion point or [basepoint/Scale/X/Y/Z/Rotate]: Enter X scale factor, specify opposite corner, or [Corner/XYZ] : Enter Y scale factor : Specify rotation angle : Command: Type the distance: *Cancel* ; error: Function cancelled Command: *Cancel* Command: *Cancel* Command: Quote
fabriciorby Posted July 2, 2015 Posted July 2, 2015 Also, you don't need the first distance/circle call you have in there. I think it's needed Quote
fabriciorby Posted July 2, 2015 Posted July 2, 2015 The direction doesn't have to be specified one direction would be fine... Hey, I've edited the code, try again, it must work Quote
Commandobill Posted July 2, 2015 Posted July 2, 2015 I think it's needed Really? Let me walk you through your code to explain: (defun c:Insert2 (/ InsObj pt js ename nw_str lastpt distpt) (initdia);brings up dialog box (command "._insert");starts command (while (> (getvar "cmdactive") 0) (command pause);;pauses for user input ) (setq InsObj (entlast))[color="red"]looking for the last object created even though nothing has been inserted yet[/color] (setq Inspt (cdr (assoc 2 (entget InsObj))))[color="red"]Getting the name of a block that has yet to be inserted[/color] (setq lastpt (cdr (assoc 10 (entget InsObj))))[color="red"]Getting the location of the blokc, yet to be inserted[/color] (while (not(setq distpt (getdist "\nType the distance: "))))[color="red"]Getting a distance from a block that has yet to be inserted[/color] (command "_.circle" lastpt distpt)[color="red"]Random circle.....[/color] (while (setq pt(getpoint"\nSpecify insertion point: <press ENTER to stop>")) (entdel (entlast)) (command "_.-insert" Inspt pt "" "" "") (setq InsObj (entlast)) (setq Inspt (cdr (assoc 2 (entget InsObj)))) (setq lastpt (cdr (assoc 10 (entget InsObj)))) (while (not(setq distpt (getdist "\nType the distance: ")))) (command "_.circle" lastpt distpt) ) (entdel (entlast)) (princ) ) Quote
Commandobill Posted July 2, 2015 Posted July 2, 2015 Still not pretty, but give this a go. (defun c:insert2 ( / dwg insPT block dir distpt ) (if (and (setq dwg (getfiled "Select Source Drawing" "" "dwg;dwt;dws" 16)) (setq insPT (getpoint "\nSpecify insertion point: "))) (progn (setq block (vla-insertblock (vlax-get-property (vla-get-activedocument (vlax-get-acad-object)) (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace)) (vlax-3D-point (trans insPT 1 0)) dwg 1.0 1.0 1.0 0.0 )) (princ inspt) (while (and (setq distpt (getdist "\nType the distance: ")) (setq dir (getpoint "\nSpecify Direction: "))) (setq block (vla-copy block)) (vla-move block (vlax-3D-point (trans insPT 1 0)) (vlax-3d-point (setq insPT (polar insPT (angle insPT dir) distpt)))) ) ) ) ) Quote
fabriciorby Posted July 2, 2015 Posted July 2, 2015 Really? Let me walk you through your code to explain: (defun c:Insert2 (/ InsObj pt js ename nw_str lastpt distpt) (initdia);brings up dialog box (command "._insert");starts command (while (> (getvar "cmdactive") 0) (command pause);;pauses for user input ) (setq InsObj (entlast))[color="red"]looking for the last object created even though nothing has been inserted yet[/color] (setq Inspt (cdr (assoc 2 (entget InsObj))))[color="red"]Getting the name of a block that has yet to be inserted[/color] (setq lastpt (cdr (assoc 10 (entget InsObj))))[color="red"]Getting the location of the blokc, yet to be inserted[/color] (while (not(setq distpt (getdist "\nType the distance: "))))[color="red"]Getting a distance from a block that has yet to be inserted[/color] (command "_.circle" lastpt distpt)[color="red"]Random circle.....[/color] (while (setq pt(getpoint"\nSpecify insertion point: <press ENTER to stop>")) (entdel (entlast)) (command "_.-insert" Inspt pt "" "" "") (setq InsObj (entlast)) (setq Inspt (cdr (assoc 2 (entget InsObj)))) (setq lastpt (cdr (assoc 10 (entget InsObj)))) (while (not(setq distpt (getdist "\nType the distance: ")))) (command "_.circle" lastpt distpt) ) (entdel (entlast)) (princ) ) I know this code is confusing (not my faulttttttt maybe next time I should consider writing a brand new one instead of trying to modify an existing one), but try reading it again: (defun c:Insert2 (/ InsObj pt js ename nw_str lastpt distpt) [color="red"](initdia);brings up dialog box (command "._insert");starts command (while (> (getvar "cmdactive") 0) (command pause);;pauses for user input )[/color] These lines are there for a reason, you've just ignored them. So, yeah, the block is already inserted by the user, and that's why it's needed haha. Quote
Commandobill Posted July 2, 2015 Posted July 2, 2015 These lines are there for a reason, you've just ignored them. So, yeah, the block is already inserted by the user, and that's why it's needed haha. I was mistaken. Sorry! Clearly it's been a long day. Quote
mbrandt5 Posted July 2, 2015 Author Posted July 2, 2015 (edited) Thanks loads for the help...that worked great... Anyway to make that snap to angles with osnaps? Also I forgot to mention that the blocks have attributes to be prompted upon insert...The actual reason for this code is to insert grid lines and replace the grid numbers/letters of the grid lines upon insertion Sorry I realize that makes things more complicated Edited July 2, 2015 by mbrandt5 Quote
fabriciorby Posted July 3, 2015 Posted July 3, 2015 Couldn't get the polar snap, but take a try (defun c:blkInsert (/ blkName cmdEcho attDia blkPoint entCircle distPoint) (if (tblsearch "block" (setq blkName (getstring "\nBlock name: "))) (progn (setq cmdEcho (getvar 'cmdEcho) attDia (getvar 'attDia)) (setvar 'cmdEcho 0) (setvar 'attDia 1) (while (setq blkPoint (getpoint "\nSpecify insertion point: <press ENTER to stop>")) (if entCircle (entdel entCircle)) (command "_.-insert" blkName blkPoint 1 1 0) (while (not (setq distPoint (getdist "\nType the distance: ")))) (command "_.circle" blkPoint distPoint) (setq entCircle (entlast)) ) (if entCircle (entdel entCircle)) (setvar 'cmdEcho cmdEcho) (setvar 'attDia attDia) ) (princ (strcat "The block " blkName " doesn't exist in your drawing.")) ) (princ) ) Quote
