fabriciorby Posted July 2, 2015 Posted July 2, 2015 (edited) Hello guys This one is huge (I guess) I have a drawing, in this drawing I want to create a table with 2 columns and 3 rows. In this drawing I have two blocks too, for each block I have one attribute. About my blocks: - Block 1: Attribute 1 - Block 2: Attribute 2 About the table: - Rows - First one: Title - Second one: Header - Third one: Data (Attributes) - Colunms - First one: About Block 1 - Second one: About Block 2 Here is a Screenshot: http://puu.sh/imk9J/fc7b6f8440.png Now, what I need to do is to link them to each other. Whenever someone change those attributes, I need the data from the table to change too. Whenever someone change the data from the table, I need the attributes from the blocks to be changed too. (I would like to try it using reactors) But it's not that simple, to implement this, I need a command to add rows to the table and a command to erase rows from the table. Whenever someone adds a row and its data, I need to add Block 1 and Block 2 with the data in their attributes. Whenever someone erase a row, I need the blocks linked to that row to be erased too. Any hints about the reactors? I really don't know how to start it. The following code creates the table and the blocks: (defun c:testing () (setq app (vlax-get-acad-object)) (setq doc (vla-get-activeDocument app)) (setq spc (vla-get-block (vla-get-activelayout doc))) (setq tabela (if (setq pt (getpoint "\nPick a point to create the table.")) (vla-addTable spc (vlax-3d-point pt) ; 3 ; 2 ; 0.2 ; 1 ; ) ) ) (vla-put-regenerateTableSuppressed tabela :vlax-true) (vla-setText tabela 0 0 "Title") (vla-setText tabela 1 0 "Block 1") (vla-setText tabela 1 1 "Block 2") (vla-setCellAlignment tabela 2 0 acMiddleCenter) (vla-setCellAlignment tabela 2 1 acMiddleCenter) (vla-put-regenerateTableSuppressed tabela :vlax-false) (block1) (block2) ) (defun block1() (setq block1 (vla-add (vla-get-blocks doc) (vlax-3d-point '(0 0 0)) "Block 1" ) ) (setq attribute1 (vla-addattribute block1 0.18 ;(/ (getvar 'dimscale) 10.0) ;altura 8 "Attribute 1" (vlax-3d-point '(0 0 0)) "Attribute1" "0" ) ) (vla-put-alignment attribute1 acAlignmentMiddleCenter) (vla-addline block1 (vlax-3d-point '(-1 -1 0)) (vlax-3d-point '(1 -1 0)) ) (vla-addline block1 (vlax-3d-point '(1 -1 0)) (vlax-3d-point '(1 1 0)) ) (vla-addline block1 (vlax-3d-point '(1 1 0)) (vlax-3d-point '(-1 1 0)) ) (vla-addline block1 (vlax-3d-point '(-1 1 0)) (vlax-3d-point '(-1 -1 0)) ) ) (defun block2() (setq block2 (vla-add (vla-get-blocks doc) (vlax-3d-point '(0 0 0)) "Block 2" ) ) (setq attribute2 (vla-addattribute block2 0.18 ; 8 "Attribute 2" (vlax-3d-point '(0 0 0)) "Attribute2" "0" ) ) (vla-put-alignment attribute2 acAlignmentMiddleCenter) (vla-addcircle block2 (vlax-3d-point '(0 0 0)) 1 ) ) Edit: To insert the blocks I'm using Unitless as unit Edited July 2, 2015 by fabriciorby Unitless Quote
rlx Posted July 15, 2015 Posted July 15, 2015 sorry but learning reactors and tables are still on my wish list (i have a waiting list for my one and only remaining brain cell...) I'll get there but not any time soon i'm afraid :-( rlx Quote
fabriciorby Posted July 20, 2015 Author Posted July 20, 2015 can you link a table in 2011? I don't know... Maybe I should make a column for the entity names and use reactors to check them everytime I change something, but the reactor part is the problem, how can I call them whenever someone changes the attributes? Quote
fabriciorby Posted July 20, 2015 Author Posted July 20, 2015 sorry but learning reactors and tables are still on my wish list (i have a waiting list for my one and only remaining brain cell...) I'll get there but not any time soon i'm afraid :-( rlx No problem, haha. Reactors are very confusing, I'm really trying to learn it Quote
Cheezee Posted July 21, 2015 Posted July 21, 2015 Got same issue when I'm doing the lighting layout.. Hope someone can get this thing work it is really very helpful Quote
