Menolik Posted December 22, 2008 Posted December 22, 2008 I'm having a bit of trouble making a 3d sping. It would be nice if someone could tell me step by step how to make one that tapers using 3dspiral.lsp so I can't screw it up. I can't seem to get anywhere with it. It ends up being a huge 2d spiral. Quote
mugshot Posted December 22, 2008 Posted December 22, 2008 create first a helix(to be used for for sweeping path) the circle (diameter of your spring) then sweep (click on the helix) Quote
shift1313 Posted December 22, 2008 Posted December 22, 2008 in acad 2007 if you type HELIX in your command prompt then follow the messages at the bottom you can create your tapered spring. It should ask you for a base location and diameter, height, and final diameter or taper(cant remember) and number of coils, then you can use a circle you draw and type SWEEP, select your circle as the object, and your helix as the path. there will be options for you to align your object to the path, twist, taper etc. just play around with these options. Quote
Menolik Posted December 22, 2008 Author Posted December 22, 2008 Thank you. It worked great. Now how would I make it have flat coils (no pitch) at the top and bottom connected to it. Quote
Menolik Posted December 22, 2008 Author Posted December 22, 2008 http://s448.photobucket.com/albums/qq203/johnsoncej/?action=view¤t=spring.gif here is a picture of what I need. It is pretty rough, but I think you'll be able to see what I need to do. I also need to know if I can control the thickness of the "wire" of the spring after it is swept into 3d. Quote
JD Mather Posted December 22, 2008 Posted December 22, 2008 I think I would use Autodesk Inventor for something like that. If you are a student you can get it for free from http://engineersrule.org And BTW there is still pitch - just reduced so that the coils are (nearly) touching. The tricky part is the transition between pitches. Quote
fuccaro Posted December 22, 2008 Posted December 22, 2008 See here: http://www.cadtutor.net/forum/showthread.php?t=78 Scroll down to the post #23 Quote
Menolik Posted December 22, 2008 Author Posted December 22, 2008 Thank you. I'll mess around with those ideas for a bit. Quote
