specify point and text settings from the command line
Hello everyone, new to this forum and relatively new to autoCAD. I'm using an Excel file to import XY coordinates into autoCAD from a set of variables. So for example, I have a column designed to produce the command point 50,10 -text @ 0.4 90 TEST where 50,10 is the coordinate, 0.4 is text height, 90 is text rotation, and TEST is the point name or number. I then copy paste the whole column into autoCAD, which works very well for me to insert multiple numbered points without the need for scripts or exporting to notepad etc. However I'm looking for a way to specify other parameters, such as point layer (POINTS), text layer (TPOINTS), text style (TPOINTS), and alignment (TL). Is this possible to do from the command line (without getting prompts)? I tried searching but to no avail. Thanks in advance.
Have a look at this you can access a lot of the sysvars from command line as well to do stuff like like change layouts layers etc. You can run lines of lisp.
osmode 0 (alert "snaps off")
osmode 16431
-la s points point 50,10 -la s text -text @ 0.4 90 TEST
clayer points point 50,10 clayer text -text @ 0.4 90 TEST
osmode 0 (alert "snaps off) clayer points point 50,10 clayer text -text @ 0.4 90 TEST osmode 16431
