How can make LINE and Circle from text file
Hi friends
I want to draw LINE and CIRCLE with different layer and color from text file anybody can help me? thx
thx jonathann3891
I have text file like this :
Column
0,0
0,20
500,20
Column
0,20
30,40
100,30
BEAM
20,20
50,20
I want seperat Column and Beam to draw them.i try this but not worked.
(defun c:Soole( / fn fp lst l p1 p2 oldOSM )
(command "_.-layer" "_N" "Column" "_M" "CCC_LAYOUT_Cross_Sections_Outline" "_C" "150" "CCC_LAYOUT_Cross_Sections_Outline" "" )
 (setq fn (getfiled "Select ASCII file" "" "txt" 4))
 (setq fp (open fn "r") lst '())
 (while
(if (/= item "COLUMN")
   (setq l (read-line fp))
   (setq lst (cons l lst))
 (close fp)
 (setq lst (reverse lst))
 (setq oldOSM (getvar "osmode"))
 (setvar "osmode" 0)
 (command "._pline" "")
 (foreach item lst
   (command item)
   (command "" "._pline")
 (command "")
(setvar "osmode" oldOSM)
