Hello friend.
How to write this function ?
(defun ins-str (str start ins-str /a b )
_$ (ins-str "af127DB" 3 "AB")
afAB127DB
Thanks for any help !
Edited by DuanJinHui
Here is a example
(defun tes (lst pos mod / qlst a hlst)
   (setq a -1)
   (setq hlst (vl-member-if-not
           '(lambda(x)
               (setq a (1+ a))
               (if (= a pos) nil
                   (setq qlst (cons x qlst))
           lst
   (if mod
       (apply 'append (list (reverse(cons mod qlst)) hlst))
       (apply 'append (list (reverse qlst) (cdr hlst))
_$(tes '(1 2 3 4 5 6) 2 0)
->(1 2 0 3 4 5 6)
_$(tes '(1 2 3 4 5 6) 2 nil)
->(1 2 4 5 6)
But this function is only for list , not for string . and (lst pos mod / qlst a hlst) "mod " must be number, can't be letter.
what can I do ?
(defun ins-str (str start ins-str)(strcat(substr str 1 (- start 1)) "AB" (substr str start)))
Then
returns "afAB127DB"
Then
returns "afAB127DB"
Hi tombu , Thank you
In function ,"AB" must replace by ins-str
(strcat(substr str 1 (- start 1)) ins-str (substr str start))
Oops! Missed that, good to see you finished that off yourself.
Happy Coding!
Happy Coding!
Thank you . tombu .
I have another question.
How extract string by a list ?
eg.
string "ABCD478EFJK" , list (2 5 6 8 )
returns "B47E"
(defun str-lst (str lst / slst)
(setq slst "")
(foreach n '(2 5 6 (setq slst (strcat slst (substr str n 1))))
Then
(str-lst "ABCD478EFJK" '(2 5 6 )
returns "B47E"
My attempt :)
(vl-list->string (mapcar '(lambda (i) (nth (1- i) (vl-string->list "ABCD478EFJK"))) '(2 5 6 ))
Oops again, forgot to use lst in the function.
(defun str-lst (str lst / slst)(setq slst "")(foreach n lst(setq slst (strcat slst (substr str n 1)))))
or Tharwat's
(defun str-lst (str lst / slst)(vl-list->string (mapcar '(lambda (i) (nth (1- i) (vl-string->list str))) lst)))
or Tharwat's
Thank you Tharwat , and Thank you tombu .
Hi tombu .
Tharwat's should be like this:;)
(defun str-lst (str lst )
Need remove Local variables
If using the mapcar approach, I would suggest assigning the list of ASCII character codes representing the string to a local variable, else the string is being needlessly converted for every index in the supplied list:
(defun str-lst ( str lst / tmp )
   (setq tmp (vl-string->list str))
   (vl-list->string (mapcar '(lambda ( n ) (nth (1- n) tmp)) lst))
Lee ,Thank you for your advice .
