Someone in my office is wanting to create a (new) lineweight. I noticed under "Form View" in the Plot Style Table Editor that the options to add/delete style are grayed out. If I select "Edit Lineweights" I can only change the value for the current lineweights. Can I create a new Lineweight value?
Thanks!
There are 27 different lineweights, you can edit the value of an existing linewight. You can't add linewights. I would recommend that you select a linewight that you company doesn't use and edit its value.
That's what I thought after my research, I just wanted to be sure I wasn't missing something. Thanks!
