Heather_H Posted July 21, 2015 Posted July 21, 2015 We have 4 drafters using AutoCAD LT 2016, 1 using AutoCAD Mechanical 2016, and 1 using AutoCAD Mechanical 2012. I have created a Hatch tool palette from our 'source' drawing (we have several tool pallettes from this file). The LT users are able to import the Tool Pallette and use the hatches with no problem. The Hatches do not work at all in the 2016 Mechanical (Mechanical or Vanilla Profile). (Hatch file pattern not found) They do work in the Mechanical for 2012, but not in the Vanilla for 2012 (same message). We have cross-referenced pathing and locations. Is there something I am missing? Thank You in advance for your help! Quote
iconeo Posted August 5, 2015 Posted August 5, 2015 Is the pattern defined in the user's acad.pat file or in a separate *.pat file? The pattern will need to be defined in whatever *.pat file you are trying to pull the hatch from. You can find it using (findfile "acad.pat") Quote
guyblack Posted September 1, 2015 Posted September 1, 2015 I also do not know the information problem Quote
RobDraw Posted September 2, 2015 Posted September 2, 2015 You and about 287,000,000 others. This sentence is so I can post "+1" because "+1" is too short. Quote
Dadgad Posted September 2, 2015 Posted September 2, 2015 (edited) This sentence is so I can post "+1" because "+1" is too short. This sentence is so I can post "+2" because "+1" is too few. Edited September 2, 2015 by Dadgad Quote
mrzer0123 Posted September 23, 2015 Posted September 23, 2015 This sentence is so I can post "+2" because "+1" is too few. so where do you think "1" is correct or "2" is more accurate. Quote
Dana W Posted September 23, 2015 Posted September 23, 2015 Can I post one of these without "+" 'ing any numerals? Quote
ROBP Posted September 24, 2015 Posted September 24, 2015 This sentence is so I can post "+1" because "+1" is too short. Or +1 is too many Quote
