084x4larry Posted July 31, 2015 Posted July 31, 2015 Can anyone help me remember that command that retains the ratio of the 2d profile lines that you extract out of a 3d part? i use solprof and then copy the 2d profile and paste it into another cad file with a 2d title block, BOM and so forth but the profile gets somewhat distorted when i paste it in..... ?? Quote
Dadgad Posted July 31, 2015 Posted July 31, 2015 If the profile block appears distorted, that makes me think that you may be experiencing a UCS problem. Compare your UCS settings, you may need to reorient your solprof images to align them in your new drawing. I have used solprof a hell of a lot in the last 3 to 4 years, and it has always behaved quite admirably. If I am not mistaken Viewbase was introduced in 2012, perhaps that would be better suited. Quote
ReMark Posted July 31, 2015 Posted July 31, 2015 There is no command to "retain the ratio of 2D profile lines" as it pertains to SOLPROF that I am aware of. Is this what you are asking about? Project profile lines onto a plane? [Yes/No] : Enter y or n, or press Enter Quote
084x4larry Posted July 31, 2015 Author Posted July 31, 2015 i finally remembered its "chspace"... keeps your profile from getting all distorted when you insert it into another drawing... How bout another question... How can i set up multileader to make the leader line always be oriented towards the center of my item balloon? Quote
rkent Posted July 31, 2015 Posted July 31, 2015 Open the Mleader style manager for that style, Contents tab, Attachment: pick Center Extents. Quote
084x4larry Posted August 4, 2015 Author Posted August 4, 2015 Thats what i thougth but even set like that "Center Extents" i keep getting this: well cant seem to attach an image but the leader keeps attaching to the side of the item ball not towards the center Quote
