I have converted some .dgn file into .Dwg when i'm try to open always showing missing font issue and .shp file kindly give me solution to rid this.
The dialog you posted occurs when AutoCAD is looking for a FONT file, not a SHAPE file.
In this case, it's specifically looking for "Eguidebig.shx"
If you have this file, then put it in the same directory as the drawing and move on.
If you don't have this file, you can replace the reference to it in the STYLE command with some other font (like SIMPLEX)
  • 3 weeks later...
how can we add micro station font in cad?
What file type does Microstation use for its fonts? If it isn't .SHX or .TFF I don't see how it could be used in AutoCAD.
