nikson Posted August 7, 2015 Posted August 7, 2015 When use trim command could not trim all segment from one point to another. I must to click more times to trim what I want. How trim in one click-select object? Quote
nikson Posted August 8, 2015 Author Posted August 8, 2015 I use trim-enter-enter and than select line for trim. Sometimes trim sucessfuly sometimes not. I thing that must to select from begining to the end (wider) to trim im one click Quote
eldon Posted August 8, 2015 Posted August 8, 2015 What is your value of the system variable EDGEMODE ? Quote
tombu Posted August 10, 2015 Posted August 10, 2015 When use trim command could not trim all segment from one point to another. I must to click more times to trim what I want. How trim in one click-select object? To trim AutoCAD needs to know the cutting edges, which objects to trim, and which side of the cutting edges to trim the objects. How could it get all that information from one click? Answer that and I'll code the solution for you. Quote
Dinochrome Posted August 10, 2015 Posted August 10, 2015 The trim command does shoe options at the command prompt. Take a little bit of time and try some of them. It can be set to default to Edge for use with a crossing window. Quote
ReMark Posted August 10, 2015 Posted August 10, 2015 I use trim-enter-enter and than select line for trim. Sometimes trim sucessfuly sometimes not. I thing that must to select from begining to the end (wider) to trim im one click My guess is you have duplicate lines (one on top of the other) or overlapping lines. Quote
RobDraw Posted August 10, 2015 Posted August 10, 2015 I use trim-enter-enter and than select line for trim. Sometimes trim sucessfuly sometimes not. I thing that must to select from begining to the end (wider) to trim im one click If you do not specify cutting edges, then all objects are selected as cutting edges. Quote
