DODGE Posted March 1, 2007 Posted March 1, 2007 Hi Guys It's one of those days today. I have just been trying the stretch command. I have never used this before today so thought it might be good to learn a bit more. I have managed to stretch items ok but not accurately. I tried to stretch a simple rectangle 200mm to the right. I hit the stretch command and make my selection, hit enter then type in 200mm enter, and it goes right off the screen. If I drag the rectangle it's fine but not accurate. This might be another dumb question, but hey you gotta ask. Dodge. Quote
kerrychivers Posted March 1, 2007 Posted March 1, 2007 To stretch your rectangle to the right 200mm (assuming your units are mm) STRETCH command. Select using Crossing of the right side of the rectangle. Type in @200,0 and it should stretch fine. Quote
Guest Alan Cullen Posted March 1, 2007 Posted March 1, 2007 DODGE.... After you make you selection, hit ENTER and then type @200 Use CROSSING to select for stretching, and if you cross the end point of any entity, you will have to deselect that entity before you hit ENTER. See if that works..... Cheers Quote
DODGE Posted March 1, 2007 Author Posted March 1, 2007 Yep tried both these. This is weird. After I use crossing to select I [email=type@200 The rectangle shoots off to the right at an angle of 12.3º. I chucked a dimension on it and it's 41m long???? What the? D Quote
Guest Alan Cullen Posted March 1, 2007 Posted March 1, 2007 I think you had better check your drawing units (UNITS) and check your direction control (part of the drawing units dialogue box). Also...are you drawing in metres or millimetres? Also check your UCS is set to world. EDIT.....also, you don't need to chuck a dimension on it to see how long it is......use the command DIST. Quote
Guest Alan Cullen Posted March 1, 2007 Posted March 1, 2007 DODGE.... Here's a lisp routine to return a distance and bearing...... ;;--------------------------------------------------------------------------- ;; BRGDIST.LSP ;;=========================================================================== ;;DESCRIPTION: RETURN DISTANCE AND BEARING BETWEEN TWO POINTS (INQUIRY) ;; ;;START COMMAND........ DI ;; ;;WRITTEN BY: ALAN CULLEN May 2002 ;; McPherson Maclean Wargon Chapman - CAIRNS ;; ;; ;;---------------------------ERROR HANDLER------------------------------ ;;(defun clerr (s) ;; (if (/= s "Function cancelled") ;; (if (= s "quit / exit abort") ;; (princ) ;; (princ (strcat "\nError: " s)) ;; ) ;; ) ;; (setvar "cmdecho" ocmd) ;; (if olderr (setq *error* olderr)) ;; (princ "\nERROR...CONSOLE BREAK...PREVIOUS DRAWING STATUS RESTORED...") ;; (princ) ; ;;-----------------------------MAIN PROGRAM------------------------------ (DEFUN C:DI () ;; (setq olderr *error* *error* clerr) ;;Set new error handler (setq ocmd (getvar "CMDECHO")) (setvar "CMDECHO" 0) (princ "\n****************************************************************************") (princ "\n BEARING & DISTANCE INQUIRY - May 2002 - Alan CULLEN") (princ) (setq pt1 nil) (print) (setq pt1 (getpoint "\n Pick required Pts ......Pick 1st Pt ...... ")) ; (while pt1 (setq pt2 (getpoint pt1 "\n Pick 2nd Pt ...... ")) (setq dist (distance pt1 pt2)) (setq dist (rtos dist)) (setq angrad (angle pt1 pt2)) (setq angdeg (angtos angrad 1 4)) (princ (strcat "\n Distance = "dist" Bearing = "angdeg)) ; (princ (strcat "\n Bearing = "angdeg)) ; (setq pt1 (getpoint "\n ......Pick 1st Pt ...... ")) ; ) (setvar "cmdecho" ocmd) ;; (setq *error* olderr) ;;Restore old error handler ; (prompt "\nRoutine terminated by User") (princ) ) Quote
DODGE Posted March 1, 2007 Author Posted March 1, 2007 Hi Al I'm drawing in millimetres. How do I make sure UCS is set to world? D Quote
Guest Alan Cullen Posted March 1, 2007 Posted March 1, 2007 Type UCS....you'll get a lot of options on the command line (it should default to WORLD...if it doesn't, just type W......try all that and get back to me. Quote
Guest Alan Cullen Posted March 1, 2007 Posted March 1, 2007 So.....are you still having stretch problems......or is everything now as it should be ? Quote
DODGE Posted March 1, 2007 Author Posted March 1, 2007 Yep Al It's still doing the same, I can't understand it. Looks like I will be giving the Autocad bible a bashing tonight. D Quote
mdbdesign Posted March 1, 2007 Posted March 1, 2007 I try on 2002, 2005, 2007 and v10 work OK even I change UCS???!!! Quote
Guest Alan Cullen Posted March 1, 2007 Posted March 1, 2007 DODGE.....post that drawing up and I'll have a look at it......probably quicker than trying to sort it out by going back and forth here... Quote
DODGE Posted March 1, 2007 Author Posted March 1, 2007 Thanks Al But I don't really have a drawing I was just playing around with a rectangle trying to learn stuff while I had a spare hour. D Quote
Guest Alan Cullen Posted March 1, 2007 Posted March 1, 2007 Hmmmm....it sounds like you have a problem with your setup in your template. Check your drawing units again, and set them to the following...... Drawing Units Length Type.....decimal precision....1 Angle Type.....Deg/Min/Sec Precision.....0d00'00" Clockwise.....tick Insertion Scale.....unitless Direction Control Base angle....North....tick I know architects use East as 0 degrees and measure angles counter clockwise, however there is no reason why you shouldn't use the cartisian system..... North......0 degrees East.......90 degrees South......180 degrees West........270 degrees Apart from that I really don't know that I can help you without having a look at your drawing template. Quote
dreamer Posted May 16, 2007 Posted May 16, 2007 Hi I have been encountering the same problem as Dodge (only on the STRETCH command though). For instant a sample 500x500 polyline square I want to stretch it to 500x800 and extend to the right. (I know I can simply draw it but here is for exercise). 1. selected objects by crossing window. 2. specifed bottom left as base point 3. specify second point: If I pick the bottom left again, press enter – nothing changed If I pick a new point. Doesn’t matter where, the whole object will move to the second picked point without change of shape. Please help. Quote
eldon Posted May 16, 2007 Posted May 16, 2007 The secret to stretching is how you select. You must use the crossing window, and any lines wholly in the window will be moved, and any lines half in the window will stretch. When you have selected correctly, and have ORTHO on, then move the mouse in the direction you want to stretch, and enter the distance at the command line. Quote
grav79 Posted May 17, 2007 Posted May 17, 2007 When you have selected correctly, and have ORTHO on, then move the mouse in the direction you want to stretch, and enter the distance at the command line. Yeah this will work, i do it the same way except using polar instead of ortho Quote
bysshe Posted February 24, 2012 Posted February 24, 2012 we've just had this problem, after trying some of the above-realised it was as simple as turning num lock back on!! Doh! Quote
