Copy & Paste very slow
When performing copy and paste between drawings the copy to clipboard command takes several minutes to complete (wheel of doom) in AutoCAD LT 2012. Drawings are 22mb with xrefs about 12mb. Something hefty in there slowing things down. Took 12 hours to complete a drawing that should only take about 1/2 hour. Need some help. Have a lot more drawings to do lol.
I already tried the following: -
purge
-purge
audit
-scalelist
overkill
wblock
Lots of multi layer embedded blocks.
Try dxfout/dxfin a couple times. Usually helps me. Then follow that up with the commands you did above.
Any particular reason the drawing would be 22MB, that's a good size drawing.
I'm just guessing, but I would check out the DGN Hotfix for LT in ReMark's link.
