fabriciorby Posted August 13, 2015 Posted August 13, 2015 Hello, I'm having a issue with my console, whenever I press the spacebar it gives me "__" instead of "_" (actually it was supposed to be a blank space, but it got messed up), and it sucks because when I want to move or copy something it gets right to Displacement as (0,0,0). Same issue with my backspace, I want to erase 1 letter I typed and it erases 2 instead... Any tips about how to fix it? Quote
fabriciorby Posted August 13, 2015 Author Posted August 13, 2015 Did you try swapping out your "console"? wow, why it doesn't work like this? but it works like this hehe sorry I just figured out in English its meant to be written as command line and not console Quote
fabriciorby Posted August 13, 2015 Author Posted August 13, 2015 I have no idea what you are referring to. Ok, let me explain better............. I have a command line, when it's not docked (http://puu.sh/jz72v/4a84df2933.png): Every time I press spacebar ("_") it prints 2 spacebar characters ("__"). And every time I press backspace it erases 2 characters instead of 1. BUT..... When it's docked (http://puu.sh/jAdEb/4f5515d242.png): It works fine. Quote
ReMark Posted August 13, 2015 Posted August 13, 2015 Then leave it docked. There are far more important things to worry about. Quote
fabriciorby Posted August 13, 2015 Author Posted August 13, 2015 Then leave it docked. There are far more important things to worry about. yeah, that's what i've already done thank you also, i found this: http://forums.autodesk.com/t5/autocad-architecture-general/command-line-space-bar-problem/td-p/4448713 Quote
