Phantom pop-up Window
I use Solidworks v 2007, and when I am in the Sweep feature, and need to select the path and profile in order to perform the sweep this window pops up. Please tell me which selections I need to make in order to select the path and profile. See attachment.
Gotchy
you should select the sketch that identifies the profile/thickness of the sweep in the green one (ex: circle, square) and select the route/path of that sweep in the pink one.
I suggest you use a newer version of solidworks, so many things changed in solidworks in 8 years. Also, I recommend this amazing book "solidworks: no experience required"
  • 2 months later...
The popup is the selection manager. The 4 options on the lower left let you do things like select a region, chain or manual selection. Ive never used 07 but the selection manager still looks very similar. Search your help file for it.
