Andrew1979 Posted August 25, 2015 Posted August 25, 2015 I am trying to place text in a certain position in paper space. I have all the co-ordinates correct but each time I run the command the text could end up anywhere around the point it should be at. Here is a portion on the code: (cond ((= myItem2 "A")(setq Pos1 "351.3,280.2")(setq Pos2 "355.9,280.2")(setq Pos3 "391.1,280.2")(setq Pos4 "400.0,280.2") (setq RevChar "A")) ) ;there are more conds I just eliminated showing them all (if (= TogRevDate "1") (progn (command "text" "j" "tl" Pos1 "0" myItem2 );Revision REV ) ) ; there are more if statements I just showed one for simplicity This is all attached to a DCL file which runs correctly. I just don't undestand this random placement Quote
rlx Posted August 25, 2015 Posted August 25, 2015 Well U can try a couple of things , just some 'field' tips. Instead of using text for your points , use (list 351.3 280.2). Check your osnap setting (turn it off). Check if your text style has a fixed height. But most important : where in your text command do you specify your text height (unless your text style has a fixed height ofcourse...) gr. Rlx Quote
Andrew1979 Posted August 25, 2015 Author Posted August 25, 2015 Thanks for the feedback.....as soon as you mentioned osnap I was sure it was the culprit.....and it was. Thanks so much for your feedback, program works perfectly now Quote
rlx Posted August 25, 2015 Posted August 25, 2015 You're welcome I've had the same experiences in the past so I too learned the hard way ;-) Gr. Rlx oh wow , I just see I went from a full member to a senile member , oh excuse me , Senior member :-) Quote
David Bethel Posted August 25, 2015 Posted August 25, 2015 You also use the _non osnap option: (command "_.text" "j" "tl" "_non" Pos1 "0" myItem2 ) -David Quote
rlx Posted August 25, 2015 Posted August 25, 2015 didn't know that option , interesting :-) , learned something today , thanx gr. Rlx Quote
