Zac Davis Posted August 26, 2015 Posted August 26, 2015 I followed this video https://www.youtube.com/watch?v=rcJ8Dczw538 im trying to create a unique copy of a pipe run , so when i change the copy it will not reflect in the original run . few problems: 1) im unable to use constraint for the copied run (in the video it acts differently) 2) how do i create a proper run , whn i say proper i mean that after ive populated the route i don't want that situation like in the picture happens and i dont know how to come back to "normal" . im taking a route from one fitting and create the path by adding segment , turning left right etc... then if i want to change a segment (not created by auto route) i type a different length . and then then the run going out from the path .. it seems like i don't know the correct flow , especially when i need to do changes . any help is well appreciated Quote
MarkFlayler Posted August 26, 2015 Posted August 26, 2015 Are you not constraining to planes or adding additional control dimensions or constraints in your route. I honestly don't have much time to go over the intricacies of the 3D Ortho routing tool but this is something I cover in my standard tube and pipe class. There is also a self paced book for this available from Ascent if you really want to dig in more and avoid random questions in a CAD forum. http://www.ascented.com/courseware-solutions/autodesk/courseware/autodesk-inventor.aspx Quote
Zac Davis Posted August 26, 2015 Author Posted August 26, 2015 Are you not constraining to planes or adding additional control dimensions or constraints in your route. I honestly don't have much time to go over the intricacies of the 3D Ortho routing tool but this is something I cover in my standard tube and pipe class. There is also a self paced book for this available from Ascent if you really want to dig in more and avoid random questions in a CAD forum. http://www.ascented.com/courseware-solutions/autodesk/courseware/autodesk-inventor.aspx I dont think my question was random , im just trying to learn. I think others can benefit from my questions too. I looked at the ascent site, seems like something ill buy. Thanks Quote
