Hi there
i found this vba code an it works perfekt when i can use the vba. but in the office there is vba restricted and so i would like to use this in a lisp:
[font=Courier New][size=2]Sub EsWerdeDunkel()
   Dim Entity As AcadEntity, Blockdef As AcadBlock, Blockref As AcadBlockReference
   For Each Entity In ThisDrawing.ModelSpace:  Entity.Color = 254: Next Entity
   For Each Blockdef In ThisDrawing.Blocks
       If Blockdef.IsLayout = False Then For Each Entity In Blockdef: Entity.Color = 254: Next Entity
   Next Blockdef
End Sub[/size][/font]
maybe there is a way to choos the color by a color-promt box...
hope you understand my english...
i don't know how to code lisp.
(i use Bricscad 14, 64Bit at office... but the lisp works the same as in Autocad)
thanks 4 help
raffi
As a quick translation of your code:
(defun c:test ( / col doc foo )
   (if (setq col (acad_colordlg 1))
           (setq foo (lambda ( obj ) (if (vlax-write-enabled-p obj) (vla-put-color obj col)))
                 doc (vla-get-activedocument (vlax-get-acad-object))
           (vlax-map-collection (vla-get-modelspace doc) 'foo)
           (vlax-map-collection (vla-get-blocks doc)
              '(lambda ( blk )
                   (if (and (= :vlax-false (vla-get-islayout blk))
                            (= :vlax-false (vla-get-isxref   blk))
                       (vlax-map-collection blk 'foo)
hi Lee Mac
not working... there is an error:
Loading D:\_Witzig\_Admin\CAD\LISP\Farbe.lsp
: (LOAD "D:/_Witzig/_Admin/CAD/LISP/Farbe.lsp")C:TEST
: TEST
; ----- LISP : Call Stack -----
; [0]...C:TEST <<--
; ----- Error around expression -----
'FOO
; error : no function definition <FOO> ; expected FUNCTION at [sYMBOL-FUNCTION]
the color selection works but after the error stop the script...
Yess... found it!
           (vlax-map-collection (vla-get-modelspace doc) foo)
              '(lambda ( blk )
                       (vlax-map-collection blk foo)
the 'foo was the mistake!
now it works...! many thanks!
hi Lee Mac
: TEST
; [0]...C:TEST <<--
'FOO
This looks to be a bug with the vlax-map-collection implementation in BricsCAD - the code I have posted performs fine in AutoCAD.
              '(lambda ( blk )
Hi Lee. Is this any different from ColorX by VVA? http://www.cadtutor.net/forum/showthread.php?533-Lisp-colour-change-for-all-layers-and-blocks&p=221559&viewfull=1#post221559
It seem to change all my blocks & nested blocks alot faster than ColorX (except the leader lines still retain color its grey colour)
Thanks
