Stanier Posted August 26, 2015 Posted August 26, 2015 Can somebody please tell me how to change the default setting of a black screen background to a white screen background. Many thanks Quote
Organic Posted August 26, 2015 Posted August 26, 2015 Type options Second tab from the left along the top of the panel I think, then the colours button or something similar. Quote
Squirltech Posted August 26, 2015 Posted August 26, 2015 Type options Second tab from the left along the top of the panel I think, then the colours button or something similar. Correct Organic. On the colors button you can select the Uniform Background and set to the desired color. (I am assuming 2000 is pretty much the same as other versions, in this case) Quote
rkent Posted August 26, 2015 Posted August 26, 2015 Options, Display tab, Color button, pick the model tab background in the dropdown, then use the color drop down for color. If you want that for Layout then use the Window Element dropdown and pick Layout, set the color as above. You can pick on the small thumbnails that appear to choose what to change, or use the drop down under Window Element. Quote
