Hello everyone,
Do you have a lisp to export drawing object to image jpg
you can see the detail below:
Did you try Command : JPGOUT ?
Plot to PDF with the DWGtoPDF.pc3 setting and then open the PDF in Acrobat and save as Jpeg.
Edited by f700es
typo
No, I directly plot to JPG with the Publish to Web JPG.pc3 setting
Yes, I understand that. Are you looking to make it easier to plot to jpg? My process, in my opinion, gives me a better output. "Your mileage my vary", as we say here in the US.
f700es the only thing to be careful of using web jpg is you need to consider the DPI ratio v's sheet size when using it, we have custom sizes like 3500x4900 this is a size in pixels or else your quality will suffer. Basicly take your sheet size plottable area and use 200 dots per inch, DPI, to re work out size (note 25.4 factor for metric) this way if you create say a A3 or 17x11 quality will be good.
Here is a TIff similar to JPg to do multiple A1 layouts.
; plot to tiff
(PROMPT ".....PRINTING DRAWING TO TIFF's....")
(SETVAR "PDMODE" 0)
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(vlax-for lay (vla-get-Layouts doc)
 (setq plotabs (cons (vla-get-name lay) plotabs))
(setq plottablist (acad_strlsort plotabs))
(setq len (length plottablist))
(setq x 0)
(repeat	len
 (setq name (nth x plottablist))
 (princ name)
 (if (/= name "Model")
     (setvar "ctab" name)
     ; **** note 0.127 scale factor for 200 DPI  ****
     (COMMAND "-PLOT"	  "Y"	     ""		"TIFF"
       "COGG A1 6mmoff"	     "LANDSCAPE"	   "N"
       "W"	  "-6,-6"    "807,560"	"1=0.127"  "C"
       "y"
  "TIFF.ctb"
          "Y"
   "N"
   "N"
   "N"
   "N"
          "Y"
 (setq x (+ x 1))
There is also a software : Universal document converter , install it , then you cap print in different kind of formats , Jpg , Pdf , Tiff also others ...
I use is a lot of time , very usefull
