Autocad is ignoring my plot styles. I think this is some type of error or bug that has happened to my drawing. YES....I do have Plot paperspace last, Plat with plot styles, and Plot object lineweights checked. I have also changed the plot style many times and it still shows up on the print preview in color and using a unknown plot scheme. I have also audited the file. Any ideas to fix this?? Thanks!
Are you using ctb or stb plot styles? Are your colors set to the standard colors, 1-255? In the viewport or in model space do you have shade style set to 2D? Is this a 2D or 3D drawing?
If using an .stb plot style, are your layers set to NORMAL or BLACK%? Normal plots color.
Is the location of the .stb file listed in your support file path?
I'm not sure of the exact wording ATM, but there is a checkbox in the plot dialog for plotting using plot styles.
There's 4 suggestions for the OP.
Let's see if we get any further input.
