hi
can someone please provide example how this might be written/work?
lets say that i wanna select all objects in curser parameter
Thanks
S
Edited by samifox
(ssget "_:E")
Full reference.
Everything within Aperture [user selection] [documented]
Allows selection of everything within the cursor's object selection pickbox. This mode may be used in conjunction with the "+." and ":S" mode strings to emulate entsel selection behaviour.
it feels like entsel....what is exctly the different?
  • entsel only allows one pick.
  • entsel only allows selection of a single object.
Did you test the expression fully before posting?
yes sure.
maybe i expectations are wrong
i was thinking that everithing under the adapture will be selected (in one click)
i see its not the case?
im after selecting multiple objects lying under or close to my pointer
When testing the expression, I am able to select all objects within the pickbox aperture using a single click.
i can see it now.
what is the right syntax for "+" ":S" ":E" combination?
Please refer to the ssget reference on my site - I have provided the link above.
i couldnt find the syntax example
It's the first example on the page... :?
:oops: my bad!
