jkristia Posted December 24, 2008 Posted December 24, 2008 I keep getting this warning - unable to offset one or more sketch entities. I have looked and looked and I can't see what the problem is, any idea how to fix this warning ? I hope you don't mind that I attached the file. Thanks Jesper Window01.zip Quote
JD Mather Posted December 24, 2008 Posted December 24, 2008 I would probably do this as an assembly rather than as a single part - but in any case you should pattern features rather than use complicated sketches whenever possible. Quote
jkristia Posted December 24, 2008 Author Posted December 24, 2008 Thanks, I changed it to pattern and equation for spacing, much simpler. I'm still curious how I could have fixed the sketch. This is for a simple model of a simple model train building, which is why I didn't bother with an assembly. Merry Christmas Jesper Quote
cedar Posted December 26, 2008 Posted December 26, 2008 Which sketch? Offsets often fail when the distance is large enough a segment gets removed Quote
