AutoCAD 2009 takes a long time to save/open single drawings?
When I open/close a single drawing AutoCAD 2009 takes a long time.
When a multiple drawings loaded in CAD it does not take so long
to close a drawings until CAD is left with a single drawing. At that time
it takes a long time to save it.
Does anyone have this problem. Is there a solution other than keeping
a second open all the time.
Thank You
don't have this problem; don't use 2009!!!
But.....do you have all the service packs?
It happening a work computer which uses 2009 so I don't have any
control on what version I use. They have updated with service packs
but I don't know which ones. Just looking for an answer why it would be doing that.
I don't like running AutoCAD with two drawings when I am only working
on one.
Thank you,
Look in the Useful Links forum for a thread I put in a short while ago. It's called Open Close Save Hotfix for AutoCAD 2009. Perhaps it might be of some use to you.
I used to have that problem when I had Vista installed, it would hang when you close the program. Now I have XP PRO and dont have that problem.
I have 09 installed on my vista machine, and it does not have that problem. I suggest the patches and then see if it is still doing it.
I also have 09 on Vista and mine only hangs for 5-6 seconds before it closes.
Used the '07 Hotfix from AutoDesk. Before the fix, took a long time
to close *.dwg files.
