Hello.
I just noticed something strange, in all documentations it says that tag string in ATTDEF cannot contain spaces, however once created I can add spaces via properties window.
How can I achieve the same within autolisp? I've tried entmod, it would not accept spaces:
(SETQ test (ENTGET
              (ENTMAKEX
                  (LIST
                      '(0 . "ATTDEF") ;Entity type
                      '(1 . "Value text can have spaces") ;value
                      '(2 . "Tag_text_cannot_have_spaces") ;tag
                      '(3 . "Prompt text can have spaces") ;prompt
                      '(10 0 0 0) ;Text first base point
                      '(40 . 6) ;Text height
                      '(70 . 0) ;Attribute flag
(PRINT test)
(SETQ test (ENTMOD (SUBST (CONS 2 "tag with spaces") (ASSOC 2 test) test)))
(PRINT test)
Also, is there a settings that makes newly created attdef tag in upper case?
Thank you.
Same issue with Attribute populated via Sheet Set Manager (SSM) Fields - adding spaces before / after within the SSM Property is ignored (even stripped), but manually editing the Attribute value to add spaces before / after SSM Field value works. Grrr
Seems like vlax-put-property works fine with changing ATTDEF tag to lower case with spaces:
(SETQ test (ENTMAKEX
              (LIST
(PRINT (ENTGET test))
(ENTMOD (SUBST (CONS 2 "tag with spaces via entmod") (ASSOC 2 (ENTGET test)) (ENTGET test)))
(PRINT (entget test))
(vlax-put-property (vlax-ename->vla-object test) 'TagString "tag with spaces via vlax-put-property")
(print (entget test))
