rlx Posted September 25, 2015 Posted September 25, 2015 rlx I tried the lisp that I told you before in 2012 and it make the same thing , so the problem is in lisp I think !!!! did you install 2012 before or after you installed 2013 (think it matters that the latest version is installed last) Only thing i can try is to test your lsp with a higher version but unfortunately i cant do it on de pc i'm working on right now. Maybe another forum user with a higher autocad version can try your routine? guys?... gr. Rlx Quote
sergiu_ciuhnenco Posted September 25, 2015 Author Posted September 25, 2015 ok rlx, sorry to bother you , I will try to reply on the original post of the lisp Quote
rlx Posted September 25, 2015 Posted September 25, 2015 ok rlx, sorry to bother you , I will try to reply on the original post of the lisp no bother really , but i just cant stand (myself) for not figuring out whats wrong I'll keep on looking for solutions gr. Rlx Quote
rlx Posted September 25, 2015 Posted September 25, 2015 no bother really , but i just cant stand (myself) for not figuring out whats wrong I'll keep on looking for solutions gr. Rlx i see you had the problem for longer in an other post. did you try the suggestion to remove all reactors? (if (vl-position "VLAX-GET-ACAD-OBJECT" (atoms-family 1)) (vlr-remove-all)) you'll never know ... gr. Rlx Quote
sergiu_ciuhnenco Posted September 25, 2015 Author Posted September 25, 2015 fix it !!!!! Thanks again !!!!! Quote
rlx Posted September 25, 2015 Posted September 25, 2015 fix it !!!!!Thanks again !!!!! I'm glad you found the solution! gr. Rlx Quote
