chelsea1307 Posted December 24, 2008 Posted December 24, 2008 Just got new backgrounds from a company and each door is its own block. the blocks are set by color instead of by layer. The doors are red which is the second thickest line on our ctb. is there a way to change all of them at once to a new color? Quote
lpseifert Posted December 24, 2008 Posted December 24, 2008 look here for Fixblock.lsp http://www.manusoft.com/Software/Freebies/Main.stm Quote
chelsea1307 Posted December 24, 2008 Author Posted December 24, 2008 i found it. I dont know much about lisps other then how to load and execute. is there a way to change it so you can select the layer you want instead of it being put on layer 0 and also by layer insted of by block? i attached it so you dont have to go search for it. fixblock.lsp Quote
Gary_W Posted December 30, 2008 Posted December 30, 2008 What you could do if its just a regular block is explode it. Then create it again but this time in Layer "0" The block will then change it attributes depending on what layer you put it in. You can do the same for a dynamic block, but obviously you will have a bit more work to do to create it again. Gaz... Quote
jammie Posted December 30, 2008 Posted December 30, 2008 Maybe this may be of some help http://www.cadtutor.net/forum/showthread.php?t=13295&highlight=block There should be a few more LISP routines posted already in this site This is a very useful routine posted by kpblc, unfortunately I can't find the original thread Author kpblc (defun c:norm (/ *error* adoc lst_layer func_restore-layers) (defun *error* (msg) (func_restore-layers) (vla-endundomark adoc) (princ msg) (princ) ) ;_ end of defun (defun func_restore-layers () (foreach item lst_layer (vla-put-lock (car item) (cdr (assoc "lock" (cdr item)))) (vl-catch-all-apply '(lambda () (vla-put-freeze (car item) (cdr (assoc "freeze" (cdr item)))) ) ;_ end of lambda ) ;_ end of vl-catch-all-apply ) ;_ end of foreach ) ;_ end of defun (vl-load-com) (vla-startundomark (setq adoc (vla-get-activedocument (vlax-get-acad-object))) ) ;_ end of vla-startundomark (vlax-for item (vla-get-layers adoc) (setq lst_layer (cons (list item (cons "lock" (vla-get-lock item)) (cons "freeze" (vla-get-freeze item)) ) ;_ end of list lst_layer ) ;_ end of cons ) ;_ end of setq (vla-put-lock item :vlax-false) (vl-catch-all-apply '(lambda () (vla-put-freeze item :vlax-false))) ) ;_ end of vlax-for (vlax-for blk (vla-get-blocks adoc) (if (and (equal (vla-get-islayout blk) :vlax-false) (equal (vla-get-isxref blk) :vlax-false) ) ;_ end of and (progn (vlax-for subent blk [color="Red"];(vla-put-layer subent "0");edit-> removed force to layer 0[/color] (vla-put-color subent 256) (vla-put-lineweight subent aclnwtbyblock) (vla-put-linetype subent "byblock") ) ;_ end of vlax-for ) ;_ end of progn ) ;_ end of if ) ;_ end of vlax-for (func_restore-layers) (vla-endundomark adoc) (princ) ) ;_ end of defun Routine will change all inserted blocks in a drawing to bylayer Regards, Jammie Quote
chelsea1307 Posted December 30, 2008 Author Posted December 30, 2008 Jammie, that worked great. Thanks Quote
