rlcad Posted September 29, 2015 Posted September 29, 2015 [using ver. 2014 of Autocad Archit.] The Help says: To Display a Toolbar: Click View tab User Interface panel Toolbars. Select a toolbar from the list. Using a newly-installed Autocad Arch. with default settings, I can't find any "User Interface" panel in the View tab of the Ribbon. The only panels are: Navigate, Appearance, Coordinates, Visual Styles, Viewports, Windows. What's wrong? Thanks. Quote
Cad64 Posted September 29, 2015 Posted September 29, 2015 I have moved your question to the Architecture & ADT section: http://www.cadtutor.net/forum/forumdisplay.php?56-Architecture-amp-ADT Quote
ReMark Posted September 29, 2015 Posted September 29, 2015 (edited) There are a couple suggestions you might try described in this link... http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Tabs-or-panels-are-missing-from-the-ribbon-in-AutoCAD.html There is a trick one can use to display a toolbar is plain AutoCAD that might work for you. It all takes place at the command line. Command: -TOOLBAR (note the inclusion of the dash) Enter toolbar name or [ALL]: standard Enter an option [show/Hide/Left/Right/Top/Bottom/Float] : hit the Enter key to accept the default. Once you have this toolbar showing you know how to get a list of the other toolbars that are available don't you? Edited September 29, 2015 by ReMark Quote
rlcad Posted September 29, 2015 Author Posted September 29, 2015 I got it, it was in a different profile. Quote
ReMark Posted September 29, 2015 Posted September 29, 2015 As I recall that was one of the suggestions in the link I posted. Glad to hear you were able to get it all straightened out. Quote
rlcad Posted September 29, 2015 Author Posted September 29, 2015 As I recall that was one of the suggestions in the link I postedSorry, should have said: "Thanks to the link you posted, I found the solution". Quote
