rlcad Posted September 29, 2015 Share Posted September 29, 2015 [using ver. 2014 of Autocad Archit.] The Help says: To Display a Toolbar: Click View tab User Interface panel Toolbars. Select a toolbar from the list. Using a newly-installed Autocad Arch. with default settings, I can't find any "User Interface" panel in the View tab of the Ribbon. The only panels are: Navigate, Appearance, Coordinates, Visual Styles, Viewports, Windows. What's wrong? Thanks. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted September 29, 2015 Share Posted September 29, 2015 I have moved your question to the Architecture & ADT section: http://www.cadtutor.net/forum/forumdisplay.php?56-Architecture-amp-ADT Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 29, 2015 Share Posted September 29, 2015 (edited) There are a couple suggestions you might try described in this link... http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Tabs-or-panels-are-missing-from-the-ribbon-in-AutoCAD.html There is a trick one can use to display a toolbar is plain AutoCAD that might work for you. It all takes place at the command line. Command: -TOOLBAR (note the inclusion of the dash) Enter toolbar name or [ALL]: standard Enter an option [show/Hide/Left/Right/Top/Bottom/Float] : hit the Enter key to accept the default. Once you have this toolbar showing you know how to get a list of the other toolbars that are available don't you? Edited September 29, 2015 by ReMark Quote Link to comment Share on other sites More sharing options...
rlcad Posted September 29, 2015 Author Share Posted September 29, 2015 I got it, it was in a different profile. Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 29, 2015 Share Posted September 29, 2015 As I recall that was one of the suggestions in the link I posted. Glad to hear you were able to get it all straightened out. Quote Link to comment Share on other sites More sharing options...
rlcad Posted September 29, 2015 Author Share Posted September 29, 2015 As I recall that was one of the suggestions in the link I postedSorry, should have said: "Thanks to the link you posted, I found the solution". Quote Link to comment Share on other sites More sharing options...
