WheneverI right click to repeat a command a box appears with 9 options beginning with enter,cancel recent input, exit, undo,pan, zoom, steering wheels , and quick calc. This is very aggravating. Don't know how it got there but how do I get rid of it?
Welcome to CADTutor
Options, User Preferences, Default Mode, Repeat Last Command
Did you know that just hitting the ENTER key will repeat the last used command? So simple even a........................
And....the spacebar represents ENTER as well.
With Options → User Preferences → 'Shortcut menus in drawing area' checked, Right-click Customization… 'Turn on time-sensitive right-click' checked Default Mode, and 'Edit Mode' set to 'Shortcut Menu' I use right-click for both Enter and Shortcut Menus. I often use Enter or the spacebar as well.
