DWG Viewer
Is there any viewer for DWG directly in Windows without entering in
AutoCAD
Guest Xenophon
i use this:
Setup_CADPreviewImage.zip
This free application enables thumbnail icons in Windows Explorer for Rhino 3DM and AutoCAD DWG files. Just download and install - that's all there is to it.
source: http://www.lynx4d.com/products.php
for PSD and AI.
The zip file contains two reg files and two dll files and full instructions on how to enable a thumbnail view in windows explorer which has been disabled by default since Adobe CS I have been using these files for a while now but had to do some research to get them to work in CS3 they work for me without any bother and it means I am able to browse with windows explorer and see thumbnails of my PSD, AI and EPS files without having to use bridge which I find is quite slow. The instructions call for editing the registry
source:http://www.istockphoto.com/forum_messages.php?threadid=51611
like this regedit to enable MAX thumbnail previews, just 1k!
EPS http://www.exefind.com/xentient-thumbnails-P19168.html (also JPG, JPE, JPEG, JP2, J2K, GIF, PNG, BMP, WBMP, EMF, WMF, PCX, PBM, PGM, PNM, PPM, RAS, TIF, TIFF, and TGA)
SVG thumbnails http://www.examotion.com/index.php?id=product_player_download
SWF http://www.swf-kit.com/swfpreview.html
and TGA http://greggman.com/pages/thumbplug_tga.htm
i also have a 3ds and Obj one but that is not free. 3d shell extensions
see:http://rbytes.net/software/3d-shell-extensions-review/
attachment fully scanned and safe with ClamWin anti-virus. trust me. shell extensions are very useful for organizing
also very useful if you run 64bit here is the 3DM shell extension for opennurbs
thumbs - psd ai.zip
regedit.zip
It is right for you to use DWGSee 2009--DWG Viewer, and this application allows you to browse, view, measure, print DWG/DWF files directly in windows without entering in AutoCAD, you may seach dwgsee and try to use this application
Hmmmmm, Bob Thomas and Reynaldo Thomas? Something smells fishy here. Perhaps this is just an advertisement for your DWGSee software? :glare:
i use this:
for PSD and AI. (see attached)
there are others too...
What are these files? Where did you get them?
The "ReadMe" says that the files contained in that zip will alter your registry settings and can potentially damage your computer. :huh:
I won't be taking that risk. :roll:
Thank you for updating your previous post to give details and instructions about the files you have attached, but I have deleted your last post. I don't think an explanation is necessary. :glare:
Have a nice day. :)
Guest Xenophon
you got it is very helpful for everybody
PS is there a reason you don't run xp 64 bit on the box in your specs?
My 32 bit home system does everything I need it to do, for now. At work, I have a 64 bit system and a render farm which I have 24-7 access to.
I may upgrade my home system someday, but at this point in time, I really have no reason.
Guest Xenophon
bring back WHIPP! (viewing of DWF made with autocad 2000 on a webpage using activeX controls)
Example use IE
  • 5 months later...
This is link as you request. This is free DWG viewer to open an AutoCAD file. The free viewer reads a DWG file as well as DXF and DWF files. A DWG file can be measured in the viewer with snap to geometry take off. enjoy free good software. (Link Removed)
Actual link to product homepage: http://www.bravaviewer.com/free-dwg-viewer.htm
Razakcisco, I have edited your post and changed the link. When providing links to software downloads, please link directly to the products homepage, not to your website where you have hotlinked to the application.
  • 4 weeks later...
thank you very much
