parksj10 Posted October 10, 2015 Share Posted October 10, 2015 Hi all, Got what I think is a dumb question I've been scouring for two hours. I use Civil 3D to create photomasks. It involves creating a lot of complex closed polylines that are filled during the conversion process to files such as GDSII. What I'm trying to do is use the Plot function to generate a PDF for someone else to view that has all the closed polylines filled in. I've seen things like Fill,SHADEMODE, etc. but I can't seem to get the objects to fill in the drawing or rendered PDF. I think the easiest thing you can tell me is from scratch, if I draw a RECT in a new .dwg file, how do I use PLOT in order to get a PDF that has the rectangle filled in? Thanks a bunch! Josh EDIT: using Windows Version of Civil 3D Metric 2016 Quote Link to comment Share on other sites More sharing options...
eldon Posted October 10, 2015 Share Posted October 10, 2015 My first thoughts would be to hatch all the closed polylines. But perhaps someone else has better thoughts. Quote Link to comment Share on other sites More sharing options...
parksj10 Posted October 10, 2015 Author Share Posted October 10, 2015 Thanks for the response. I thought about that, but I have thousands of objects that need to be filled in the pdf render. I feel like there should be an easy setting (like in my dxf conversion program) that simply fills the closed lines during plotting Quote Link to comment Share on other sites More sharing options...
RobDraw Posted October 10, 2015 Share Posted October 10, 2015 In drafting, that is not a common thing to do. Sorry, no easy button included with AutoCAD for that, but I'm sure it could be done with LISP. Quote Link to comment Share on other sites More sharing options...
mikekmx Posted October 10, 2015 Share Posted October 10, 2015 In drafting, that is not a common thing to do. Sorry, no easy button included with AutoCAD for that, but I'm sure it could be done with LISP. that sounds the route. 1 click, done. OP - try posting what you want (hatch all closed polylines in the dwg with solid hatch) in the LISP sub-forum. perhaps try searching the forum first - may have been discussed before. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted October 10, 2015 Share Posted October 10, 2015 See your other post please dont post twice its confusing. Quote Link to comment Share on other sites More sharing options...
parksj10 Posted October 11, 2015 Author Share Posted October 11, 2015 See your other post please dont post twice its confusing. I only posted twice because mikekmx told me to do so. Should I delete this one? Quote Link to comment Share on other sites More sharing options...
