I have one Auto-cad drawing where I have pasted excel spreadsheet, Now my customer wants check boxes on it to verify the quantity of material or part numbers etc. so anyone know how to insert check boxes in Auto-cad because not I don't have that much of time for editing excel & paste it in Auto-cad.
Thanks.
If you don't have that much time, you might be out of luck.
Using AutoCAD tables to create a data link is a much better way to handle getting Excel into AutoCAD. Much better than pasting. Set up a good table style or you can do all your formatting in Excel.
Rob,
Thanks but I tried that option too, I cannot see that check boxes in auto-cad when I add that table. still I am trying autocad entities.
First off, can you explain exactly what you mean by check boxes and include a couple screen shots of of what you have and what you want.
Tables is the solution, if you are using Excel. If you focus on that, you will get what you need. Maybe not the way you envision it but it does work.
I have attached where I Have Inserted check box but when I insert it in autocad it is not showing.
I can't make that work but you can make a block of a check mark and insert it into cells.
