cond() - why ((t nill)) is common way to end the sublist?
hi
(cond
  ((= s "Y") 1)
  ((= s "y") 1)
  ((= s "N") 0)
  ((= s "n") 0)
  (t nil)
usually functions return nill when an empty value is issue, in cond returning nill is exposed to the developer...why?
So why its a common way?(according to docs)
I think it is just an example to beginners to know the use of t symbol with cond function and nothing's more.
Is there any use of t byond the self explained true?
As far as I know , no.
The use of t at the end of cond function is to pass any value you want if the arguments that passed to the function are not to equal to any value.
Not sure what u mean...
Do you know what is the use of symbol t at the end of cond function?
As i understand....if t equal to t...than return nill
Or maybe its a defult if none is true. But why?
No, if the variable s is not equal to either "Y" "y" "N" "n" the t symbol at the end would give you an option to set the variable ( for example ) to any value you want or print a message to user etc...
So its a defualt action in case none of the expression is true? So its could be (t (prints "illegel value"). So t is just a trigger in endcof the cond?
Close , have a look .
(cond
  ((= s "Y") 1)
  ((= s "y") 1)
  ((= s "N") 0)
  ((= s "n") 0)
  (t (alert "Variable (s) in not equal to any of the above check outs "))
(cond
  ((= s "Y") 1)
  ((= s "y") 1)
  ((= s "N") 0)
  ((= s "n") 0)
Its not what i meant?
Put simply, a test expression of 't' will always be validated and so this represents a default condition for when all other conditions are not met; such a condition is by no means necessary, but usually provided by the documentation to help explain how to include a default condition.
It looks like you understand this.
The equivalent in another syntax style could be
if (s=="Y")
return 1
elseif (s=="y")
return 1
elseif (s=="N")
return 0
elseif (s=="n")
return 0
else
alert( "Variable (s) in not equal to any of the above check outs ")
endif
Think of (t ....) as being an all-inclusive "else" or "otherwise".
