Is it possible to change the position parameters at properties menu? For example, (as shown in the screenshot) "Distantce3" move to the first line, and "Distance1" on the third line.
I need it, for example if there is a dynamic block with many parameters. And to add one parameter - AutoCAD default setting makes this the bottom line in the properties. And I need that to this option in the properties was the first line.
in 2013 if you use the prameters manager in the block and select "convert parameter" for D1 and D2, then convert them back D3 will be at the top of the list, not exactly easy or fast.
In "Parameters manager" in the block I find column "Order" and the problem is solved. Thank you!
