tmelancon Posted October 22, 2015 Share Posted October 22, 2015 I currently have a routine that imports Page Setups from a master file. Its like 20 plus page setups. My question is that when this routine runs and a drawing currently has one or more page setup being re imported then it prompts the user with a Y or N if they would like to redefine. I do not want this infringing on my CAD guys, and just wish to import and redefine automatically and silently if necessary. So they are not bothered. See code below. (DEFUN C:PSN () (command "._-PSETUPIN" "G:/DESKTOP/PAGE SETUPs/MASTER_Page_Setups.dwg" "*")(PRINC)) Any help would be appreciated. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
iconeo Posted October 22, 2015 Share Posted October 22, 2015 Have you tried changing your EXPERT variable yet? Quote Link to comment Share on other sites More sharing options...
tmelancon Posted October 23, 2015 Author Share Posted October 23, 2015 Ahhh Expert. That did the trick. Worked like a charm, only issues(which really isnt a problem) is how it shows all 20 plus page setups redefining in the command line.. Arghh I dont suppose cmdecho would work or something like that? Quote Link to comment Share on other sites More sharing options...
iconeo Posted October 23, 2015 Share Posted October 23, 2015 It definitely should Quote Link to comment Share on other sites More sharing options...
tmelancon Posted November 6, 2015 Author Share Posted November 6, 2015 I am back again, I have tried to no avail to silence the redefining of these page setups. Nothing works. Any suggestions of something I can add to the existing code to make this happen? Quote Link to comment Share on other sites More sharing options...
tombu Posted November 6, 2015 Share Posted November 6, 2015 Try setting NOMUTT to 1 Quote Link to comment Share on other sites More sharing options...
tombu Posted November 6, 2015 Share Posted November 6, 2015 Take a look at functions getPageSetupName, deletePageSetup and addPageSetup defined by code http://jtbworld.com/autocad-pagesetup-lsp. You should be able to use getPageSetupName to test for the Page Setup you want to replace and use deletePageSetup to delete it if needed, and use addPageSetup to add the one you want. No command functions used so nothing should show up on the command line. Quote Link to comment Share on other sites More sharing options...
BlackBox Posted November 7, 2015 Share Posted November 7, 2015 I just use this: http://forums.augi.com/showthread.php?80461-Page-Setup-Manager&p=1219546&viewfull=1#post1219546 Example: (foreach layoutname (layoutlist) (vla-SetActivePageSetup layoutname “[color="red"]YourPageSetupName[/color]”) ) Cheers Quote Link to comment Share on other sites More sharing options...
