In my ongoing study into DFX group codes I wrote the following little lisp, which works fine.
(defun c:rrr ( / ent entdef n ss x)
 (setq x (getstring t "\nEnter text to overwrite: "))
 (if (setq ss (ssget "_:L" '((0 . "TEXT,MTEXT"))))
(setq n 0)
(repeat (sslength ss)
(setq ent (ssname ss n))
(setq entdef (entget ent))
(setq entdef (subst (cons 1 x) (assoc 1 entdef) entdef))
(entmod entdef)
(setq n (1+ n))
   (princ "No Text Selected. Please Try Again")
My question is, can the lines:
Be reduced to two (or even one) line without changing anything else or using those fancy vl-functions?
It's the entget bit I'm struggling with, to put into the other lines
Perhaps something like this
 (defun c:rrr (/ entdef ss x)
   (if (and (setq x (getstring t "\nEnter text to overwrite: "))
            (not (eq x ""))
               (entmod (subst (cons 1 x) (assoc 1 (setq entdef (entget (ssname ss (setq i (1- i)))))) entdef))
       (princ "No valid text to overwrite was entered. Please Try Again")
EDIT: Sorry, fast reading...
(setq entdef (subst (cons 1 x) (assoc 1 (setq entdef (entget (ssname ss n)))) entdef))
Henrique
Thank you very much Henrique.
That's much tidier & shorter. And not one vl-gizmo anywhere! That’s the best thing about this forum, there’s always an expert like you or Lee willing to help a newbie like me.
I admit that it took me quite a long time to write this short lisp, several of the functions are new to me.
As for your initial post, I had intended adding the “(if (and” error prevention, but simply hadn’t got that far, I still need to keep it as simple as possible before adding such luxuries!
You're welcome, Happy Hobbit
Glad I could help
Henrique
Happy Hobbit you may want to think about using a library of little defuns, pushing my own wheelbarrow from now on I use the getvals.lsp that allows me via 2 lines to 1 2 3 or more lines of a dialouge to appear without writing any dcl code ; sample code (ah:getval3 "Length" 5 4 "Width" 8 7 "Height" 6 4) http://www.cadtutor.net/forum/showthread.php?93002-1-line-2-line-3line-dcl-auto-generator-plus-more-if-required&p=636641&viewfull=1#post636641
Working on a commercial product which in nearly every routine changed layers and other settings had 3-4 lines in every routine but each line was worth around 20 lines of code in the library.
You probably need to compare number of characters typed v's actual number of lines you have not saved much in this particular example. People like Lee & Tharwat are great on reducing size of actual code.
