Hello everyone. I'm wondering how I would edit the vertex of the box that is located on the upper left hand corner. Thank you.
What do you want to do to it?
I haven't had 2012 in a while so I don't know if this will work but pick on the box and look for grips to use. Or hold CTRL down and pick on the vertex and use the grips, assuming that worked back in 2012.
What I would like to do is move the vertex. I tried doing that I picked the box and used the grips and that didn't work all that did was move the WHOLE BOX. I would like to move that vertex while the box reminds static.
Is the cube by chance a 3D object? If so, it will not edit like a regular polyline set. You'll have to edit it according to the parameters for the particular type of entity it is.
Are you sure about this? There has to be away to edit this vertex.
Click on the object and give us a screen shot of the properties box, is this a solid, a block, an object with thickness, a surface model, a groep........or just a collection of loose lines ?
Not until you answer the question.
I can do it in a few steps, convert to a Mesh, stretch the vertex, convert back to solid.
