Civardi Posted October 26, 2015 Posted October 26, 2015 I want to convert this attached objects (polyface mesh) to a solid so I can cut a section of it. Can anyone help? new block.dwg Quote
ReMark Posted October 26, 2015 Posted October 26, 2015 I tried a multi-step process I've used in the past which has worked (sometimes) but this is not one of those times. Of the six portions of the model I tried to convert I was only successful with two. The remainder generated errors such as... -inconsistent containment of intersection curve -system inconsistency processing edge coincidence -face containment cannot be determined -inconsistent edge-face relationships Maybe someone else here will have better luck. Quote
