cookieguy20000 Posted October 26, 2015 Posted October 26, 2015 Hi all, Each time i need to edit a text, i always have to tap the Backspace button. This button is pretty far from my left hand(when my right hand is holding the mouse), so i wonder if anyone knows how to copy it's function into another button, for example the button " ~` ", which is next to button "1", as far as i know it's pretty useless. Thanks!!! Quote
tombu Posted October 26, 2015 Posted October 26, 2015 As long as your right hand is on the mouse anyway why not just drag the curser to select the space and start typing? \U+08 will enter the ASCII for backspace you could probably create a Shortcut Key for it in the CUI under Keyboard Shortcuts. Quote
Cad64 Posted October 26, 2015 Posted October 26, 2015 As long as your right hand is on the mouse anyway why not just drag the curser to select the space and start typing? That's what I do when editing text. I rarely ever use backspace. Quote
eldon Posted October 26, 2015 Posted October 26, 2015 Perhaps you could do a Google search on "remap backspace key" Quote
iconeo Posted October 31, 2015 Posted October 31, 2015 If you have a mouse with more than the standard buttons it would be easy to just map one of the extra buttons to backspace. Quote
