broncos15 Posted October 26, 2015 Posted October 26, 2015 I created a simple code for AutoCAD 2013, that is having some issues in 2015. It will run correctly, but if I press the space bar after running the command to invoke it again, I get the response "Unknown command "Dimaligned2". I can fix this issue by using the command-s function, which doesn't make sense to me because I thought command-s couldn't be used with the "pause" command token. My code is as follows: (defun c:dimaligned2 ( / OLDECHO) (setq OLDECHO (getvar "cmdecho")) (setvar "cmdecho" 1) (command-s "._dimaligned" pause "_perp" pause "@" pause "") (setvar "cmdecho" OLDECHO) ) My original code is: (defun c:dimaligned2 ( / OLDECHO) (setq OLDECHO (getvar "cmdecho")) (setvar "cmdecho" 1) (command "._dimaligned" pause "_perp" pause "@" pause "") (setvar "cmdecho" OLDECHO) ) Quote
hmsilva Posted October 28, 2015 Posted October 28, 2015 Hi broncos15, you have an extra 'enter' in "._dimaligned" command, try the following (defun c:dimaligned2 ( / OLDECHO) (setq OLDECHO (getvar "cmdecho")) (setvar "cmdecho" 1) (command "._dimaligned" pause "_perp" pause "@" pause) (setvar "cmdecho" OLDECHO) (princ) ) It works as expected in AC2015? I did test the code in AC2012/4/6, I don´t have AC2015... Henrique Quote
broncos15 Posted October 29, 2015 Author Posted October 29, 2015 Hi broncos15,you have an extra 'enter' in "._dimaligned" command, try the following (defun c:dimaligned2 ( / OLDECHO) (setq OLDECHO (getvar "cmdecho")) (setvar "cmdecho" 1) (command "._dimaligned" pause "_perp" pause "@" pause) (setvar "cmdecho" OLDECHO) (princ) ) It works as expected in AC2015? I did test the code in AC2012/4/6, I don´t have AC2015... Henrique That works perfectly. Man that was a stupid error by me, thanks for catching it. Quote
hmsilva Posted October 29, 2015 Posted October 29, 2015 You're welcome, broncos15 Glad you got it working. Henrique Quote
