TheAllusionist Posted November 2, 2015 Posted November 2, 2015 AutoDesk Architecture 2016 installed and it doesn't show "Precision" option in the context sensitive right click shortcut menu when a dimension is selected and right mouse button is selected. PickFirst, etc. are set correctly, what is wrong is that a corrupted install or something happened and the shortcut menu for precision is empty. There is no .0, .00, .000........ data tables in it, so it doesn't show because it is empty. I know ACAD pretty well, but pretty much customize through keyboard aliases and autolisp and do not customize menus, etc.. Can someone tell me if there is a way to import the information into the table either from another location in 2016 or from ACA 2015? Precision works from the properties table, just a lot more efficient to have it in the right click menu. Thanks in advance for your time. Russell Quote
rkent Posted November 2, 2015 Posted November 2, 2015 First look in the CUI, Shortcut Menus, Dimension Objects Menu. Is there a submenu for Precision? If not add it and then drag and drop the Dimension, Precision,0 and other under that submen. Quote
TheAllusionist Posted November 2, 2015 Author Posted November 2, 2015 Perfect, thank you, just had to drag and drop the different precision levels into the shortcut precision menu item from the dimension section below. PROBLEM SOLVED Quote
