Hello, when trying to export a pipe to microdrainage I get this error below from civil 3d?
I started this network from scratch from civil 3d not micro drainage now wanting to export to micro drainage.
I’m using UK civil 3d 2016 and windows 10 64bit
My pipe names are 1.000, 1.001 and so on.
Thanks Dean
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
System.IndexOutOfRangeException: Index was outside the bounds of the array.
at MDLink.CmdExportFile.ExportFile()
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.PerDocumentCommandClass.Invoke(MethodInfo mi, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke()
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.6.106.0 built by: NETFXREL2STAGE
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Acdbmgd
Assembly Version: 20.1.0.0
Win32 Version: 20.1.107.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/AcdbMgd.DLL
System
Win32 Version: 4.6.79.0 built by: NETFXREL2
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
adui20
Assembly Version: 0.0.0.0
Win32 Version: 20.1.49.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202016/adui20.DLL
ACAD-G21001-WORKING MODEL (C3D).dwg
